Thread: Audi A4 B8 - VAG.com Tricks
Page 1 of 44 12311 ... LastLast
Results 1 to 10 of 435
  1. Audi A4 B8 - VAG.com Tricks
    Mar 2009
    Willerby, East Yorkshire....
    Hi...
    Trying to compile a list of all the tricks that can be done to your car using VAG.com
    1. LED DRL's full brightness all the time when using indicators, fog lights or driving lights.
    2. Remove seat belt chime.
    3. Auto closing of sunroof or windows when arming the car.
    4. Sweeping needles on speedo / rev counter on startup of the engine.
    5. Enabling Lap Timer on the DIS.
    6. Emergency brake flashing (brake lights and parking lights flash in hard braking)
    7. Enable hidden MMI menu.
    8. DVD SatNav eject lock.
    If you know of any more just add them to the list...
    One more thing, does anyone known if it's possible to enable the BLIP on lock and BLIP BLIP on unlock.
    I had it done to my Golf GTI and it was great...
    Martin
    Gone... A4 S Line 2.0T Quattro S Tronic Plus Options. Here... A5 S Line Special Edition 2.0TDI Quattro Manual With HDD Tech Pack...
  2. Re: VAG.com Tricks...
    Jan 2009
    Essex
    I've done all the above apart from 6 - isn't that default.
    The first one I did was add "honk on alarm"
    I've also changed it so that the rear lights are active with the DRLs.
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  3. Re: VAG.com Tricks...
    May 2008
    Where do you get the vag.com kit from?
    What about the passenger mirror dipping when selecting reverse?
  4. Re: VAG.com Tricks...
    Jan 2009
    Essex
    www.ross-tech.com (make sure you're sitting down when you get to the price page)
    Mirror dipping is something that only cars with Comfort pack i.e. memory can do.
  5. Re: VAG.com Tricks...
    May 2008
    Cheers Scottyuk, stuff paying that. Would be nice to have the needles bounce round on start up and have rear light on with DRL's but not for that price!
  6. Re: VAG.com Tricks...
    Jan 2009
    Essex
    Most people don't buy it for just that.
    Both my TT and my S4 were modified so it's nice to be able to keep a look out for any problems before you have to go to the dealer.
    As an example, on my S4 the car showed no problems. I plugged in my Vag-com and it showed an intermittent loss of signal from a knock sensor. Now since the car was tuned up to nearly 400bhp, knock sensors are quite important! If I hadn't had my vag-com, I'd have run it until the next variable service e.g. 17k miles without knowing. As it was I took it to the dealer and they resolved it under warranty
    Most Vag-com owners will help other people out. This is where car meets are useful. I've done many peoples cars ...although I'm stupid as the most I've ever taken off anyone in payment is a BigMac meal
    A token gesture is normally all that is required as people are not just provinding the tool but f course they're giving up their time as well.
    Many forums have Vag-com sections where owners will post their locations and offer their services. The only this is....just because someone (i.e. me!!) has the tool and can see the disagnostic messages, it doesn't mean they're an engineer and hence they may not know how to solve any issues found but at least you know about them.
  7. Re: VAG.com Tricks...
    Mar 2009
    Hi...
    That's great...
    I've a local VW / Audi Independent service garage that I can go to for VAG.com stuff
    Last time I was there for a VAG.com session he charged me £20 + VAT.
    I just need a list of what I need doing for when my car arrives.
    Martin
  8. Re: VAG.com Tricks...
    Mar 2009
    Hi...
    Can we start adding the code settings, so that anyone like me can print it off and take it to some one and asked them to to this....
    Found these on another website.
    Removing Seatbelt Chime
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
    Uncheck the box for "Seatbelt Warning active"
    [Do It!]
    Enabling Gauge Test/Needle Sweep
    This will sweep the gauge needles through their full range automatically when you start the engine.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check the box for "Gauge Test/Needle Sweep active"
    [Do It!]
    Enabling Lap Timer
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check the box for "Lap Timer active"
    [Do It!]
    Operating Windows and Sunroof with Remote
    (Note, the sunroof cannot be opened with the remote)
    You need to continuously hold the remote button for the function to operate.
    [Select]
    [46 - Cent. Conv.]
    [Coding - 07]
    Click on each of the Byte numbers in line 3) and you'll see the selectable options below.
    Check the box for "Comfort Operation: Remote Control active"
    [Transfer Coding]
    [Do It!]
    Martin
  9. Re: VAG.com Tricks...
    What does the hiddem MMI menu give you?
  10. Re: VAG.com Tricks...
    Jan 2009
    Essex
    It gives the ability to access lotsa of options that 99% of people don't know what they do
    On top of that you can turn on the car battery level graph so that when you go into CAR you have an extra option which shows the state of the battery. To be honest it's a gadget rather than a feature
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  3. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
