Thread: Audi A4 B8 - VAG.com Tricks
Page 44 of 44 FirstFirst ... 34424344
Results 431 to 438 of 438
  1. Re: Audi A4 B8 - VAG.com Tricks
    Jan 2019
    Looking for a wee bit of help.
    I'm relatively new to messing around with MMI and recently bought a carista plug in OBD2 adapter. I used it to customise some of my features, like adding the sound when opening and locking the car and the needle sweep on start up. I was also able to activate the hidden MMI menu and the ADS option.
    ADS now appears in the car menu option and I can choose between the standard options or select them individually. I notice a difference in throttle response when selecting dynamic mode but don't really notice a difference in steering response.
    Should activating this work automatically? Are all require components factory fitted and just not activated?
    I have an A4 2.0 tdi 2015
  2. Re: Audi A4 B8 - VAG.com Tricks
    Jan 2013
    newport wales
    Hi,apologies if this has been asked but can the 12v accessory plug be adjusted tostay on after the ignition has been turned off, read somewhere that it can beadjusted to stay on for 99 minutes or is that a myth.
    I have an A4 AvantB8.5 2013
  3. Re: Audi A4 B8 - VAG.com Tricks
    Jan 2013
    newport wales
    Or is this not a VAG.com adjustment and I have to set to a different fues block where there is permanent power
  4. Re: Audi A4 B8 - VAG.com Tricks
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by glen40 View Post
    myth
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  5. Re: VAG.com Tricks...
    Mar 2021
    us
    Quote Originally Posted by ScottyUK View Post
    Most people don't buy it for just that.
    Both my TT and my S4 were modified so it's nice to be able to keep a look out for any problems before you have to go to the dealer.
    As an example, on my S4 the car showed no problems. I plugged in my Vag-com and it showed an intermittent loss of signal from a knock sensor. Now since the car was tuned up to nearly 400bhp, knock sensors are quite important! If I hadn't had my vag-com, I'd have run it until the next variable service e.g. 17k miles without knowing. As it was I took it to the dealer and they resolved it under warranty
    Audi Hatchback Details
    Used Audi A4 for Sale
    Audi Q5 For Sale
    Audi S4 For Sale
    Most Vag-com owners will help other people out. This is where car meets are useful. I've done many peoples cars ...although I'm stupid as the most I've ever taken off anyone in payment is a BigMac meal
    A token gesture is normally all that is required as people are not just provinding the tool but f course they're giving up their time as well.
    Many forums have Vag-com sections where owners will post their locations and offer their services. The only this is....just because someone (i.e. me!!) has the tool and can see the disagnostic messages, it doesn't mean they're an engineer and hence they may not know how to solve any issues found but at least you know about them.
    Hi...
    That's great...
    I've a local VW / Audi Independent service garage that I can go to for VAG.com stuff
    Last time I was there for a VAG.com session he charged me £20 + VAT.
    I just need a list of what I need doing for when my car arrives.
    Martin
  6. Question Re: Audi A4 B8 - VAG.com Tricks
    Oct 2025
    Iver, UK
    Hi folks, new here so guide me to a better section if appropriate.
    I have a 2013 S-Line which I believe should have DAB on the MMI but it's not showing as an option, just AM/FM. Is this possibly a software issue or do I aso need more hardware (aerial etc)? 2nd question, I've read that it's possible to set the kerb camera to drop when selecting reverse but mine doesn't. I have also seen that some say this only works with the memory function and I'm not sure what that means...I have the Jukebox function which is memory / storage...is that a clue? Any guidance greatly appreciated.
  7. Re: Audi A4 B8 - VAG.com Tricks
    Aug 2010
    Leicester
    I remember the passenger door mirror dipped in reverse, maybe that was dependent on having memory seats, I don't know?
    Have you got the list of build numbers (as far as I remember there was a copy in the user manual, and a copy in the spare wheel well?) that might tell you if you have DAB or memory seats (but the buttons shuld exist on driver;s door if you have that
    it seems deathly quiet around the a4/b8 section nowadays :-(
    2017 A5 sportback, 2.0TFSI, quattro, S tronic, S line, virtual cockpit, mythos black.
  8. Re: Audi A4 B8 - VAG.com Tricks
    Aug 2010
    Leicester
    What you're looking for under the boot, or in the service manual looks like this
    Google Search
    If you google, there are decoders for the numbers ...
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  3. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
