Thread: Audi A4 B8 - VAG.com Tricks
Page 2 of 44 FirstFirst 123412 ... LastLast
Results 11 to 20 of 438
  1. Re: VAG.com Tricks...
    Jan 2009
    North Yorkshire
    I seem to remember on my TT it was possible to do a factory re-set which tightened up throttle response etc.Certainly on my Merc C Class I could do this and it was great .It meant if you had been lazy on the throttle for a while you could get a re set which meant it was much sharper.Can you do that on the A4 ?
  2. Re: VAG.com Tricks...
    Jan 2009
    Essex
    You're thinking about the Throttle Body Alignment.
    I've not tried it yet but I'd expect so :
    http://wiki.ross-tech.com/index.php/...Alignment_(TBA)
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  3. Re: VAG.com Tricks...
    Jul 2008
    Devon
    would love to have a play around with some of these settings - i'm due a service soon so might see if i can get some changed at same time
    anyone had experience of the cheaper Vag-Com cables available on Ebay ?
    £30 v's £300 for the rosstech one ?
    seems the rosstech one acts as an activation dongle for their software - is the freeware version any good for minor tinkering like altering the settings mentioned ?
    B8 2.7 TDi debadged multitronic saloon S-Line 20mm drop in monza silver , sat nav , milano leather , cruise control , hill hold , advanced parking , advanced key , Bluefin chipped 236BPH 470NM , TPMS and ADS activated via VAG-COM
  4. Re: VAG.com Tricks...
    Feb 2009
    Where The Sun Don't Shine ...
    Quote Originally Posted by 2.7 S-line View Post
    Beat me too it!
    Audi S4 Black Edition Saloon
  5. Re: VAG.com Tricks...
    Jan 2009
    Essex
    You're only paying a bit for the cable. Most of it is to use the software hence why Ross-Tech put a dongle in the cable. You can download a free old version of the software which is fine on cars 5 years old etc but with our using the CAN bus you need a fairly up to date version.
    Did you really think people throw big money at it if it could be done very cheap
    p.s. You can actually do it a lot cheaper. THere are applciations out there for £25 or so that run on Iphones etc and use wifi to talk to a ODBII adaptor which is about £100.
    I know that Biscuit on Tyresmoke.net has this solution but since I'd already bough mine I've not looked into it.
  6. Re: VAG.com Tricks...
    May 2008
    Can you use the MMI hidden menu on a Concert system or do you have to have NAV/MMI High ?
  7. Re: VAG.com Tricks...
    #17
    Nov 2008
    Cheshire
    Would these work on an 09 A3? Also, does anyone know how to make electric folding mirrors automatically fold in when the car is locked and out when unlocked/started, as my A3 doesn't do this, you must turn the knob.
    2009 Audi A3 2.0 TDI S Line Black Edition in Ibis White
    Modifications - Remap (P Torque) | Weitec Hicon GT Coilovers | H&R 10mm f /12mm r Spacers
    Eibach 26mm f /23mm r ARB's | Number plate/interior "Ultra" LEDs | Sound proofed doors
  8. Re: VAG.com Tricks...
    #18
    How do you unlock the hiddem MMI menu ? got ross tec 805.1 (down load)
    (A6 Avant 2.7tdi s line)
  9. Re: VAG.com Tricks...
    #19
    Jan 2009
    Essex
    Picked off another forum :
    Hidden menu in MMI high:
    STG 07 - Control Head
    STG Adaptation -> Channel 8
    change 0 to 1
    Use this hidden menu at your own risk.
    Caution: Keep away from the "Bootloader".
    STG 09 – Cent. Elect.
    STG Coding -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    STG 17 - Instruments
    STG Coding -> Long Coding Helper -> Byte 1
    Bit 0 – Gauge Test/Needle Sweep (1 = active)
    Bit 3 – LAP-Timer (1 = active)
    Consumption in DIS:
    STG Adaptation -> Channel 3
    change 100 to 104
    Sample 1:
    FIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100/9,3*9,8 = 105,38)
    Channel 3 will be changed from 100 to 105
    Sample 2 :
    FIS: 7,8 l/100 km.
    Real: 6,9 l/100 km. (100/7,8*6,9 = 88,46)
    Channel 3 will be changed from 100 to 88
    DVD navigation eject lock:
    STG 37 - Navigation
    STG Adaptation -> Channel 68
    0 = button active
    1 = button inactive (anti-theft)
    http://wiki.ross-tech.com/index.php/Audi_A4_(8K)_Navigation
    STG 46 - Comfort System
    STG Coding -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    Phone voice control:
    STG 77 - Telephone
    STG Coding
    00x0x?0 - The 2nd to last digit should be changed to 2 (English (UK))
    http://forums.audiworld.com/showthread.php?p=23587701
    http://wiki.ross-tech.com/index.php/Audi_A4_(8K)_Telephone_Preparation_(MOST)
    In intend to activate both Brake flashing mods. I did a test the other day and at a 60mph full on emergency stop the hazards didn't come on. No idea why it's not activated as I can't see any downside.
    I'm also gonna turn on the flashing brake lights. I've previously looked at an add on device so if the car can do it then why not!
  10. Re: VAG.com Tricks...
    #20
    Sep 2008
    Can you enable quattro with it?
    ... Or just buy some badges (sorry... couldn't resist)
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  3. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
