Thread: slave cylinder
  1. slave cylinder
    May 2009
    home
    hi all ive started to lose hydrylic pressure on my touran to the point you press the pedal half way down before you feel any thing and the clutch bite is at the very bottom now.this morning i have removed the slave cylindr and the spring in there has all plastic melted to it one end looks very warn.
    is the slave cylinder fed its oil through the brake reservior aswell.?
    also how do i remove the clip of the cylinder?
    thanks in advance guys
  2. Re: slave cylinder
    Jan 2009
    Hi my clutch bite is also very low on the pedal and i to am assuming the clutch master cylinder is fed from the brake reservoir. As the reservoir is full i can only assume that my clutch is about ready to be replaced as i still have good pressure there.
    Did you have to remove much to remove the clutch master cylinder?
    Sorry there's no new info for you.
    Selston, Nottinghamshire
    guys, i have the same problem, but my clutch has just been replaced!!
    i collected the car on saturday took it for a long drive and the pedal dropped at 7pm that same night!!!
    i will return to the garage on monday (tomorrow) and let them know i have this problem!
    History of V.A.G. Cars Owned:-
    2001 A4 Avant SE AJM 1.9 TDI -2011 A4 Avant SE 140PS 2.0 TDI - 2005 BXE VW Passat 100PS Highline 1900 TDi - 2006 Touran 1900TDi 105PD - 2003 Audi A4 1.9TDI Avant Quattro Sport
    2003 Audi A4 1.9TDI Saloon Quattro Sport - 1983 VW Golf GTi 1800 Mk1 - DX - 1978 VW Golf GTi 1600 MK1 (LHD Import) - EG(00004) - 1978 VW Polo N
  1. 80 2.6 clutch slave cylinder
    By johnlyn in forum 80 - 90
    Last Post: 26-12-2007, 06:43 PM
  2. A4 1.9TDI clutch master to slave cylinder pipe
    By optimobi in forum Audi A4 - Archive Topics
    Last Post: 23-02-2007, 04:30 PM
  3. Clutch slave cylinder
    By nik in forum 80 - 90
    Last Post: 08-01-2007, 11:13 AM
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
