Thread: which ones the wiper relay ?????
Results 1 to 10 of 13
  1. which ones the wiper relay ?????
    Aug 2008
    Cheshire
    n
  2. Re: which ones the wiper relay ?????
    Aug 2008
    Cheshire
    p
  3. Thumbs up Re: which ones the wiper relay ?????
    Sep 2007
    I've just had a look at my Haynes manual which only covers up to 1999 but it shows the front window wiper motor relay has 6 x spade connectors on it. (If you remove the relay check the brass or silver coloured spade shaped connectors which slot into your fuse box, it should have 6) When removed you might see U/5, U/6,U/7, U/8, U/9 & U/10 where these spade shaped connectors slot into the fuse box. I'll scan the wiring diagram in the morning & post it here if you still need it.
  4. Re: which ones the wiper relay ?????
    1836 Post(s)
    As I said previously, the 9N Polo uses a central electrics system. The wipers are controlled from the on board power supply unit which controls many functions on the car. You cannot play guess work with this unit or even substitute another unit as they are coded to the car. It needs to be fault code read.
  5. Re: which ones the wiper relay ?????
    Aug 2008
    Cheshire
    q
  6. Re: which ones the wiper relay ?????
    1836 Post(s)
    Or a indi VAG specialist who knows about the central electrics unit.
  7. Re: which ones the wiper relay ?????
    Aug 2008
    Cheshire
    a
  8. Re: which ones the wiper relay ?????
    Dec 2010
    Australia
    Which number on the board is the relay? Replaced wiper stalk too and still no go. Is this off a T4 Transporter?
  9. Re: which ones the wiper relay ?????
    1836 Post(s)
    What car have you got?
  10. Re: which ones the wiper relay ?????
    Dec 2010
    Australia
    Hey dude. Its a 98 VW Transporter 2.0 perol. The only thing that works on the wiper stalk is the rear wipers. The stalk has been changed and same problem. I have the wipers wired to a switch so they are working. Any ideas?
  1. Please Help rear wiper relay
    By Decker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2009, 11:03 AM
  2. wiper motor relay
    By Simo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2009, 12:41 PM
  3. Transporter Wiper Relay
    By johnhorrig in forum The Commercial Range
    Last Post: 12-03-2008, 11:17 PM
  4. Intermittent Wiper Relay - HELP!
    By Steve P in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-06-2007, 01:00 PM
  5. wiper relay
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 22-01-2007, 11:21 PM
