Just fitted a new water pump and belt to my Polo,
Before I took it off, I marked both camshaft pulleys and the bottom pulley.
Before I start the car I would like to check that everything is correctly aligned.
Been told that the cam pulleys should be lined up with the 3 dots facing each other and the crankshaft at T.D.C.
I can't find any marks on the bottom pulley, apart from the ignition timing mark, which is positioned at around twenty past the hr when the camshafts are in position.
Anybody got a diagram or picture of how they should be aligned.
Rgds
Jimmy.
