Thread: crafter cruise control retro-fit
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: crafter cruise control retro-fit
    Apr 2013
    West Midlands uk
    Something's never change eh gups? Retro fitting out the van now? Have you done everything on the A6 now? Didn't think I would see you on this section, you or A6Chris haha
  2. Re: crafter cruise control retro-fit
    Sep 2011
    Lurking over a keyboard ...
    Recently was scanning by van after a service done by dealer (as still under warranty) and can see coding option in module 01 which I swear was not there in past VCDS versions.
    Can also now access ESP/ABS module but coding box unavailable and adaptations didn't show anything relating to CCS but will contact Ross Tech to see if they have update on CCS retro fit.
    Here is attachment of my VCDS scan, Link:- Log-lt3.txt
    The fault codes IMO are just erratic flag ups over the last year as I've had no issues and not scanned van for months, cleared DTCs and not come back.
    *** edit ***
    Viewing this post Link:- Activating cruise control crafter..HELP
    Perhaps all I need is to change coding in module 01 via long coding helper?
    Perhaps it's finally time to buy the CCS kit?
  3. Re: crafter cruise control retro-fit
    Sep 2011
    Hi fellow VWAF'ers!
    The coding in VCDS is not correct IMO for the CR 2.0 TDi, solution in video!
    I will later add scans of the MY13 crafter I used to get coding.
    ATB
    G
    *** Edit ***
    Module 01 coding comparison
    63 plate CR35 MWB HR (MY13) PS109 Bluemotion with factory fit A/C & CCS
    01 19 40 12 20 44 0D 08 00 00
    12 plate CR35 MWB HR (MY12) PS136 without factory fit A/C & CCS
    01 19 40 10 20 04 0C 08 00 00
    A/C coding , CCS Coding , unknown coding (suspect start stop system)
    Autoscan of 63 plate CR35 MWB HR (MY13) PS109 Bluemotion with factory fit A/C & CCS
    Code:
    Wednesday,19,December,2012,14:45:27:06090
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 2E - VW Crafter (LT3)
    Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
              B0 B1 B2 B3 B4 B5 B6 C1
    VIN: WV1ZZZ2EZDxxxxxxx
    Address 01: Engine (J623-CKTB)       Labels: 03L-906-012-CKT.clb
       Part No SW: 03L 906 012 P    HW: 03L 906 012 A
       Component: R4 2,0L EDC   H23 2860
       Revision: 72H23---    Serial number: VWXDZ0L1021174
       Coding: 0119401220440D080000
       Shop #: WSC 00000 555 00117
       ASAM Dataset: EV_ECM20TDI01103L906012P 002011
       ROD: EV_ECM20TDI01103L906012P.rod
       VCID: 31633E2F603E90909EB
    No fault code found.
    Readiness: 0 0 0 0 0
    Autoscan of 12 plate CR35 MWB HR (MY12) PS136 without factory fit A/C & CCS
    Code:
    Wednesday,17,September,2014,13:44:50:06090
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.8.1.0
    Data version: 20140905
    VIN: WV1ZZZ2EZCxxxxxxx   License Plate: xx12xxx
    Mileage: 18633   Repair Order: 14.8 beta test
    Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
    Address 01: Engine (J623-CKTC)       Labels: 03L-906-012-CKT.clb
       Part No SW: 03L 997 403 A    HW: 03L 906 012 A
       Component: R4 2,0L EDC   H23 5815
       Revision: 72H23---    Serial number: VWXDZ0K1043573
       Coding: 0119401020040C080000
       Shop #: WSC 131071 1023 2097151
       ASAM Dataset: EV_ECM20TDI01103L997403A 002001
       ROD: EV_ECM20TDI01103L997403A.rod
       VCID: 30653B2B6B3499BA69-8065
  4. Re: crafter cruise control retro-fit
    Sep 2015
    U.K.
    Hi mate , I can activate your cruise control! Where are you live?
  5. Re: crafter cruise control retro-fit
    Jan 2009
    I have a 62 plate crafter with retro cruise kit fitted. VW useless trying to get it activated. Anybody local to Nottingham that can get it activated. Cheers👍
  6. Re: crafter cruise control retro-fit
    May 2017
    london england
    I need mine set in and cannot do wit any of my machines can you help or do this please mark@m88solotions.com
  7. Re: crafter cruise control retro-fit
    #17
    Apr 2018
    Warwickshire
    Hey there all, I know this is all old but wanted to know is activating cruise control on a crafter more readily available now? As want it done to my 2013 2.0
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. Question Retro Fit Cruise Control & Auto Hold..?
    By Pimped-Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-08-2008, 01:47 PM
  4. Retro fit cruise control...
    By bluetba in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-10-2007, 08:16 PM
  5. Retro fit A3 Cruise control
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 10:59 PM
