Thread: Coolant Leak From Coolant\Water pump Housing
  1. Coolant Leak From Coolant\Water pump Housing
    Feb 2009
    Hi all,
    I returned to my car yesterday (1999T, 1.8T 20V) to find a rather large pool of coolant under it. I checked the level in the tank and it was about 1cm under min (at weekend it was full) as I was at work I topped it up and got home.
    Once at home I got under the car and could quite visibly see a drip coming from the housing of the coolent pump. When I cleaned it all up so I could properly identify where it was leaking, I noticed a little hole that looked like a inspection hole of some sort?? close to the shaft where the pully and belt are, so it is on the opposite side from the thermostat. It was quite a regular drip maybe one every 2 seconds. So last night I took off the filler cap and left it be, as I couldn't do anymore.
    This morning it hadn't leaked?! So I put the cap back on and drove to work, once again it was leaking so I have left the cap off again tonite.
    I have searched the internet to no avail today, alot seem to leak at the seal to the block, but mine is definately leaking at the opposite end to that. I have had many suggestions including water pump, but nothing I can rely on.
    Oh and one other thing, I put a new thermostat in about a month ago, but it has been good a gold, so I don't suspect that! Also the drip is no where near that.
    I'm scratching my head big time! HELP
  2. Re: Coolant Leak From Coolant\Water pump Housing
    Norfolk
    If you are sure it's the pump, then the seal on the shaft has gone. This lets water get into the drive shaft space that has a little hole in to let the water out. You need a new pump in that case.
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. A3 coolant leak
    By hensojm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-11-2009, 12:22 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Trans oil or coolant leak....any help?
    By Daza-1979 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2007, 11:53 PM
  5. 2001 Passt TDi Coolant leak
    By g4ryhunt in forum Passat - Archive Topics
    Last Post: 15-11-2006, 07:07 PM
