Thread: 2000 Polo E uneven tickover
  1. 2000 Polo E uneven tickover
    Jan 2006
    I'm sure this is a "known" problem. 999cc polo E ,ever since it was a couple of years old suffers intermiitently with uneven tickover and needs a few more revs when pulling away than normal, to prevent stalling. I took it to the dealer a couple of times who even charged me while under warranty to clean out something?- but only cured it temporarily. Doesn't seem to follow any patern, hot or cold & sometimes ok for a couple of weeks. Can anyone help please ?
    Jan 2006
    Had a similar problem with a Polo 1.4CL R reg ('97) once.
    All I did was to take the air intake apart on top of the engine and clean the butterfly valves and inlet chamber. There's two valves, a throttle and a choke in a vertical formation. Dirt gets around the edge of the valves (mainly the lower choke valve) causing erratic tick-over and occational stalling from cold. It's quite an easy job. You'll need something like a 5mm Allen key to remove the throttle housing on the top of the air inlet housing on top of the engine.
  1. 2000 Polo - x Reg - Help please?
    By mellowmunkee in forum Polo - Derby - Lupo - Fox
    Last Post: 03-01-2008, 07:08 PM
  2. 2000 Bora TDI PD - uneven idle
    By Boraman in forum Bora - 1998 - 2005
    Last Post: 29-04-2007, 09:57 PM
  3. Uneven Tickover
    By Tvr in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-10-2006, 11:16 PM
  4. VW POLO 1.3i tickover problem
    By burt in forum Chat - Completely Off Topic
    Last Post: 11-04-2006, 09:34 AM
  5. Polo Tickover Flutters
    By sazzle1 in forum Polo - Derby - Lupo - Fox
    Last Post: 31-01-2006, 11:24 PM
