Regarding the above motor. The clutch pedal occasionally goes a bit 'limp' when depressing. By hooking my foot behind the pedal I can pull it back out and continue on my way.
I've had a look under the bonnet and this model seems to have a hydraulic clutch. Just wondering if the problem is likely to be with the master/slave cylinder, a spring in the pedal assembly or a spring on the clutch itself.
Thanks in advance for any help.
Cheers,
Sam
