Thread: Brake problems
Results 1 to 8 of 8
  1. Brake problems
    Apr 2009
    Hi I have just joined the forum and wonder if any one can help i had a rear wheelbearing fitted on my 1999 s4 and now when I press the brake pedal i get a banging sound I have check every thing is nipped up and it is , and there are know abs lights on can any body help
  2. Re: Brake problems
    1840 Post(s)
    Single bang or repeated?
    Bowkers of Lancashire.
  3. Re: Brake problems
    Apr 2009
    Repeated until you stop. I also had new rear calipers and pads fitted at the same time...
  4. Re: Brake problems
    1840 Post(s)
    Do you get the feeling it is per wheel revolution and one side or the other?
    I wondered if you were a Bowker from Lancashire?
  5. Re: Brake problems
    Apr 2009
    It only happens when i press the brake pedal it feels like something is loose but i have checked everything.
    I'm from Manchester
  6. Re: Brake problems
    1840 Post(s)
    You need to get it inspected as it may be dangerous.
  7. Re: Brake problems
    Aug 2008
    Norwich
    Have you checked the hub? Also is the disc correctly aligned and not warped? Sounds like the disc is not running concentric and when you brake it is pulling it into alignment with the pads.I,ve had this happen on another car.
  8. Wink Re: Brake problems
    Apr 2009
    Booking it in at audi only in Manchester to have it checked thanks for the advice
  1. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  2. Electrical problems, no brake lights
    By wookiee_rob in forum Scirocco - Corrado
    Last Post: 27-03-2008, 11:21 PM
  3. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  4. help - problems with my brake lights!
    By katy in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2007, 01:01 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
