Thread: 1998 golf cabrio idle problems
  1. 1998 golf cabrio idle problems
    Mar 2009
    can anyone tell me why sometimes my car stalls or the rpm drops and then returns to normal. this only happens when im driving (slowing down for a junction)
  2. Re: 1998 golf cabrio idle problems
    1840 Post(s)
    The throttle body is dirty and needs removing, cleaning and then re-adapting to the ECU using a diagnostic system such as VAG-COM. I am assuming this is a 2.0L with an AGG engine?
  3. Re: 1998 golf cabrio idle problems
    Mar 2009
    Yes it is I will sort out the throttle body to see if this cures the problem..
    Cheers!!
  4. Re: 1998 golf cabrio idle problems
    I'm intending to attempt this tomorrow as I'm having the same problem. Unfortunately though I haven't yet bought a vag-com cable - will it definitely need re-adapting or if I'm careful will it be fine without?
    Thanks in advance
  5. Re: 1998 golf cabrio idle problems
    1840 Post(s)
    Remove and clean it but you may find you have a high idle after. Just buying a fleaBay VAG-COM cable won’t help you, it has to be a registered version of VAG-COM so you will have to go to the Ross Tech web site and pay $99 to register the software to be able to perform the adaptation.
  6. Re: 1998 golf cabrio idle problems
    Removing it looked a bit complicated I don't think I've got the right tools to remove some of the pipe fasteners and I didn't want to break them so I just took the air intake off and cleaned the throttle body on the car with a bit of carb cleaner and a soft cloth.
    Idle is noticably smoother and when you clutch in whilst coming to a stop it catches it at about 850rpm rather than dropping to 400ish or stalling.
    Thanks for the advice!
  7. Re: 1998 golf cabrio idle problems
    Mar 2009
    Nice one I try that first and all you done was clean and no adaption or modifications needed afterwards.
    Let me know as Ill have ago at this tommorrow if thats the case....
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. 1990 Golf GTi cabrio misfiring
    By Dave Clark in forum Archive posts
    Last Post: 04-06-2007, 07:53 PM
  3. Mk3 Golf Cabrio - Starter Problems
    By alexmcc in forum Golf MK3 - 1993 - 1999
    Last Post: 01-06-2007, 11:47 PM
  4. Any advice appreciated-MK IV Golf problems!
    By Pantalaimon in forum Golf MK4 - 1999 - 2004
    Last Post: 06-12-2005, 09:00 PM
  5. GOLF PLUS PRICES AND SPECIFICATION ARE REVEALED
    Last Post: 02-05-2005, 09:24 PM
