Thread: '98 1.6 AKL and VAG-COM
Results 1 to 10 of 10
  1. '98 1.6 AKL and VAG-COM
    Apr 2009
    Hi guys,
    I bought a cable off ebay as my immobilizer kept cutting my car out (see other thread: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=66965)
    I just wanted to know if anyone else had any issue communicating with the ECU?
    I did an Autoscan and it didn't find anything but it seems to have erased the fault code which was making the immobilizer cut the engine so is now running
    Can anyone shed any light 'cause I'm confused as to how the problem is now fixed although I couldn't communicate with the ECU?
    Thanks,
    Kris
  2. Re: '98 1.6 AKL and VAG-COM
    1837 Post(s)
    Which software level?
  3. Re: '98 1.6 AKL and VAG-COM
    Apr 2009
    Quote Originally Posted by crasher View Post
    which software level?
    409.1
  4. Re: '98 1.6 AKL and VAG-COM
    1837 Post(s)
    You cannot have the autoscan on the free shareware version of 409 as shown in the first line here
    http://www.ross-tech.com/vag-com/vag-functions.html
    You will have to register it here,
    http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VSWR&Categor y_Code=VAGCOM
  5. Re: '98 1.6 AKL and VAG-COM
    Apr 2009
    I have the full version
  6. Re: '98 1.6 AKL and VAG-COM
    1837 Post(s)
    Is it registered with Ross Tech or is it a cracked version?
  7. Re: '98 1.6 AKL and VAG-COM
    Apr 2009
    I'm not quite sure, its kind of a friends of a friend laptop I borrowed but apparently its for dumb interfaces such as the cable I have. Is there any issues with the cracked or properly registered software? is there anywhere I can look to see if the version is a legit or a cracked version?
    Thanks,
    Kris.
  8. Re: '98 1.6 AKL and VAG-COM
    1837 Post(s)
    I don’t know, I only use a legitimate copy of VCDS and my old dumb interface ran 311 (legit) and then I went over to a dongle interface with 5 something so I have never used 409. We aren’t even allowed to discuss illegal versions on here. You will have to contact Ross Tech.
  9. Re: '98 1.6 AKL and VAG-COM
    Apr 2009
    Ok thanks for the info. so do you know if V.311 is ok with the AKL ECU? If so, then the updated version should be too if its an update, it should be better not worse (its not like its developed by Microsoft where compatibility issues seem to be going backward lol.
  10. Re: '98 1.6 AKL and VAG-COM
    1837 Post(s)
    I used to use 311 on AKL engines without a problem.
  1. VAG COM cable
    By lw2 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2009, 04:36 PM
  2. Cheap VAG COM options for a novice
    By witblitz in forum VCDS - General Questions
    Last Post: 20-03-2008, 02:08 PM
  3. Changing Accelerator Cable
    By nexuss in forum Bora - 1998 - 2005
    Last Post: 24-02-2008, 01:54 PM
  4. Bora 1.6 engine judders 2000-2500rpm
    By cbhero46 in forum Bora - 1998 - 2005
    Last Post: 09-11-2007, 03:04 PM
  5. Throttle body fault
    By Jay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-02-2007, 02:51 PM
