Thread: 17544 fault code, help
  1. 17544 fault code, help
    norfolk
    engine management light came on and i scanned for fault codes and 17544 came up which is a fuel trim too lean or something along those lines. i done some research on that fault code and im thinkin its either 1 of 2 problems, air leak or MAF.
    before the light came on, i just set off after stopping at some lights and while in 3rd gear accelerating, there was a massive misfire, as the misfire happened my engine management light and epc light both flashed and went out again and the car just carried on as normal.
    anyone have any ideas on what i should do/check etc?
  2. Re: 17544 fault code, help
    Southern County Softy
    20 Post(s)
    Check for leaking pipes, clear the fault code and see if it comes back..
    A4 2.5 tdi QS (mapped)
  3. Re: 17544 fault code, help
    norfolk
    i've cleared the fault codes and it keeps coming back. everytime i've cleared the fault code, i always come across that major misfire and a flash of both engine management and epc light. if it is an air leak then im a little bit stuck cause theres so many pipes, i dont know whats what lol.
  1. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  2. P0411 fault code??
    By colina3 in forum Audi A3 - Archive Topics
    Last Post: 18-02-2008, 01:29 PM
  3. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
  4. fault code 17544
    By Lee Toone in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2007, 01:14 PM
  5. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
