Thread: Loud noice coming from steering
  1. Loud noice coming from steering
    Jan 2009
    hi guys can anyone help please. I have a 2000 x reg golf gt tdi 6 speed. what has happened is that whilst the car is stationary and the tyres are loaded and i turn the steering to the right it makes quite a few nocking, clocking noices this only on the odd ocasion happens when i turn left. also when i reverse the car it somethings makes a screatching noice. when i drive the car the noices disapers as the tyres dont have much weight put on them. Also when i rock the steering whilst stationary there is a knocking noice from the steering. ALL THE NOICE'S COME FROM THE RIGHT HAND SIDE OF THE CAR/WHEEL O/S/F
    THANK YOU FOR YOUR HELP....
  2. Re: Loud noice coming from steering
    Apr 2007
    The knocking when stationary is probably trackrod inner ends. Not sure about the creaking. My Bora creaks when turning left at low speeds. This could be the rack or maybe a top mount & bearing.
  3. Re: Loud noice coming from steering
    Jan 2009
    i have changed both track rod end either side or is it the part that holds the track rod ends
    cheers
  4. Re: Loud noice coming from steering
    Apr 2007
    The inner ends, ie: the bits covered by plastic bellows coming out of the steering rack.
  5. Re: Loud noice coming from steering
    Jan 2009
    Had a similar issue with my golf turned out to be bottom swivels and bushes on both front arms. hope this helps.
  6. Re: Loud noice coming from steering
    Jan 2009
    i have changed both front arms, but i bought them from ebay and they looked like they were the cheap/nasty type but they were were brand new will all the bushes. i dont think the arms are gone on mine i took it to a garage and he said let the problem develop so it is quite bad because nobody knows where it is coming from thank you for your help
  7. Re: Loud noice coming from steering
    Dec 2007
    I had knocking in my steering, turned out to be the column. It was replaced at just 12,000 miles.......VW reliability?
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  3. Sloppy steering
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 04-06-2008, 02:49 PM
  4. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
  5. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
