Thread: Airbag Crash Sensor in a wet footwell
Results 1 to 10 of 13
  1. Airbag Crash Sensor in a wet footwell
    Jul 2007
    Co Durham
    The airbag light on my 2001 Passat has come on. Caused by water in the footwell underneath the passenger seat. Apart from stopping the leak in the first place, once that is done how can i sort out the sensir? Will it come back to life if dried out? Is it a replacement job and will that automatically extinguis the warning light?
  2. Re: Airbag Crash Sensor in a wet footwell
    Norfolk
    I doubt water in the footwell put the airbag light on. Did you disturb the wires under the passenger seat. You need a vag-com read to identify where the airbag fault is.
  3. Re: Airbag Crash Sensor in a wet footwell
    Jun 2008
    mine was the passenger side crash sensor took it out and cleaned it but light still on cant get a code read done something wrong with plug under dash anyone an idea of the price of a new sensor or why my plug isnt workin it will power code reader then keeps coming up error
  4. Re: Airbag Crash Sensor in a wet footwell
    Jan 2010
    midlands
    had mine changed today, it was £104 + vat just for the sensor.
    I had the same problem water on the passange side floor.
  5. Re: Airbag Crash Sensor in a wet footwell
    Jun 2008
    just got a quote for 122.50 didnt think it would be that expensive , did it cure your problem
  6. Re: Airbag Crash Sensor in a wet footwell
    Jun 2008
    has anyone got a part number for pass side crash sensor please
  7. Re: Airbag Crash Sensor in a wet footwell
    Feb 2007
    my airbag was deployed was wondering if taking it off and cleaning it makes a difference as vagcom shows up resistance too low???
  8. Re: Airbag Crash Sensor in a wet footwell
    uk
    Just an update for this thread, priced up crash sensor today £135 + VAT, at present my car is without passenger seat and glove box with carpet peeled back trying to dry things out, still haven't traced leak but it looks like pollen filter area, any advice?
    What are the thoughts on using part finder and fitting a used item, would there be any guarantees from supplier?
  9. Re: Airbag Crash Sensor in a wet footwell
    uk
    I've fitted a used crash sensor, I thought it worth a punt at £20 and leak has now been sorted.
    The sensor I've been supplied with has come with a different part number so hoping it will be ok. At present seat is still out while carpet dries, once the seat wiring is re connected should the dash board warning light go out or will it have to be reset?
    Also thinking of buying a code reader, I've seen them for about £15 will this just be to read codes or is it considered that it will clear/reset also? Anyone??
  10. Re: Airbag Crash Sensor in a wet footwell
    uk
    Could anyone comment on thoughts, thanks
  1. 1998 A4 Airbag Controller - need recode number
    By jhutchison in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-09-2008, 05:32 PM
  2. Passenger Airbag Deactivation Fault
    By jluckcuck in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 21-05-2008, 10:50 AM
  3. Air bag fault codes: Which airbag do I need to look at?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 10:17 PM
  4. Air con making rear footwell wet?
    By Dfardon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2008, 10:52 AM
