Thread: rear window
  1. rear window
    Mar 2009
    is there a way of alter the rear window as it does not seem to come togeather enought ie on the passingers side the front and rear window seem to come to geather more resulting in the two coming closer to geather on the sear but on the drivers side it does not come togeter enough at the very top there is no gap but is not over lapping as much as the other
    hope that makes sencse
  2. Re: rear window
    Dec 2006
    Nope... does not make much sense...
    Is it a saloon, Avant or Cab?
    I take it you mean there is a gap between the front and rear glass door glass on a A4 cab when the windows are closed??
    Can you re explain..
    Rick
  3. Re: rear window
    Mar 2009
    sorry mate yes ment to put that in yes its a cab and like you say the windows dont meet upfully on the drivers side well not as much as the passenger side
  4. Re: rear window
    Feb 2009
    Ok, word of warning, if you do this incorrectly you WILL shatter your window (I DID!!!)
    Make sure the window is fully closed
    Remove speaker cover:
    1) the wood trim - insert screwdriver under front of the trim and prise out - clip at rear has to be moved out
    2) remove speaker cover
    Behind the speaker cover you will see 3 holes in the absorbing trim - 2 are above the speaker, the third is actually behind the speaker
    3) loosen these 3 nuts
    4) Adjust window to where it should be with the door closed making sure the glass is level at top (have someone help you hold the glass) - make sure the gap on the glass plane is equal from top to bottom.
    5) Tighten the 3 nuts but be careful not to overtighten - according to Elsawin the torque should be 6NM.
    6) If you have a gap between the door window and the rubber strip on the rear window loosen the big nut behind the speaker
    7) remove the side trim and rubber strip on the inside of the window and loosen the 2 black nuts underneath it (goto http://www.wit-usa.com/sms/db/smartt...a4_v1.2/en.php for instructions on how to remove side panel)
    8) adjust so there is no gap by moving the whole window mechanism out.
    9) Tighten the nuts and then tighten the big nut behind the speaker (2NM)
    10 reassemble the speaker cover
    Should only take 10-20 mins
    BTW, if you have not done the smarttop mod do it - it makes the roof much more usable:
    a) close roof while driving at up to 25mph
    b) close roof from key fob - roof closes and car locks while you walk away
    c) open roof from key fob
    d) one touch open/close using switch
    If you need any more info let me know.
    Walter.
  1. Rear Window Heater Problem
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-01-2008, 11:44 AM
  2. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  3. How does the Quattro system work?
  4. changing rear door window
    By lukassk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2007, 02:51 AM
