Thread: VW golf MK4 showing ABS light and warning sign
Results 1 to 10 of 11
  1. VW golf MK4 showing ABS light and warning sign
    Apr 2009
    Hi everyone... new to the forums, ive got a problem with my 1999 T reg Golf MK4....basically when i start the ignition the abs light satsy on (engineer said might be sensor) but anither light is and explanation mark that lights up and beeps...
    any idea what fault this is?
    Thanks,
    Joe
  2. Re: VW golf MK4 showing ABS light and warning sign
    Dec 2007
    crawley, west sussex
    Hiya, this has happened to my passat today, abs warning light now stays on, i now have no brake lights so check yours, hooked it up to my scanner & i got a fault code 00526, this should hopefully mean a faulty brake switch which costs about a £10er & around half an hour to fit yourself, do a search on here, there is quite a bit of info, hope this helps mate.
  3. Re: VW golf MK4 showing ABS light and warning sign
    Apr 2009
    my brake lights work fine.... strange these on board systems.... a good old 1989 polo would of been good for me ....but i'll definetly have a search or call colbornes...
    Thanks,
  4. Re: VW golf MK4 showing ABS light and warning sign
    Apr 2009
    searched for an answer....still cant find one, any idea?
  5. Re: VW golf MK4 showing ABS light and warning sign
    Mar 2008
    Bradford, West Yorkshire.
    A scan would be a good start.
    The fault code it gives would point you in the right direction.
    Registered VCDS (VagCom) owner. v812xx Hex&CAN.
    Bora Highline 130pd ST3'd (Fast Road map) to 170bhp & 300lbft (ish!)
  6. Re: VW golf MK4 showing ABS light and warning sign
    N/A
    same thing happened with mine a while back, turned out to be the MAF sensor !
    get your fault code read that should help to pin point your problem !
  7. Re: VW golf MK4 showing ABS light and warning sign
    Mar 2008
    I have both the lights on my 2001 bora tdi. I hace vagcom and it turned out to be the wheel speed sensor on the drivers side. Changed this as it was knackered but the light is still on. As I was changing it I noticed the hub was had a little movement so im guessing it this that causing the lights to come on. ABS and brakes are working fine. If your in Manchester could do a scan for you.
  8. Re: VW golf MK4 showing ABS light and warning sign
    Aug 2009
    London
    i still have this problem
  9. Re: VW golf MK4 showing ABS light and warning sign
    Aug 2010
    manchester
    Quote Originally Posted by bora185 View Post
    i really could do with some help im in manchester and have this abs light problem...ive paid twice and still had no luck finding the fault..if your close could u hook me up to your vagcom pleaseeeeeeee :0)
    0 seven nine 0 two 0 seven 0 000 mark
  1. engine warning light in golf mk4 1.6
    By McW in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2009, 08:24 PM
  2. Why new ABS Unit if no ABS warning light?
    By kaygolf in forum Golf MK4 - 1999 - 2004
    Last Post: 23-01-2009, 12:55 AM
  3. Engine warning light on MK4 golf with LPG
    By Simonharris in forum Golf MK4 - 1999 - 2004
    Last Post: 16-05-2008, 06:30 PM
  4. VW Golf GTi Mk3 permanent ABS warning light
    By macka in forum Golf MK3 - 1993 - 1999
    Last Post: 28-05-2007, 11:19 PM
  5. VW Golf gt tdi 115 ASR light & ABS light
    By wez326 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-01-2007, 02:25 PM
