Thread: Stuck Wheel Bolt
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Stuck Wheel Bolt
    Jan 2006
    PRESTON, LANCS
    Thanks to a over zealous a***hole who fitted new tyres for me and tightened my security wheel bolt up to epic proportions --im now left with a problem . On trying to undo the bolt- in order to remove wheel to replace pads --- It was so so tight -- that despite all my efforts -even with a 'knock gun' --the splines on the bolt were stripped bare .
    So --looks like its gonna be a drilling out job --unless someone else has any ideas ?.
    When and if --i get this sorted --im gonna change all 4 of those silly security bolts for normal bolts --seeing as my alloys are nothing special .
  2. lock bolts
    Dec 2006
    Newport South Wales
    had same thing.audi bolts not that steady when leaning on them. mine were not quite wrecked, local garage used air gun just got it out. good idea to change em did mine for more solid type so you can get wrench on properly, good luck.
    sean
    recently picked up q5 special edition. Kept a4 b8.
    Oct 2005
    Sounds as though you went to Kwik Fit or somewhere similar.
    If you haven't already tried - 6ft scaffold pole slipped over the end of your favourite torque wrench.
    Jan 2006
    PRESTON, LANCS
    Too late for this im afraid -- bugger all to get hold of now . Like Sean said --when removing the bolts -- its crucial to keep the wrench straigh --otherwise it chews the splines up.
    Quick fit ? nope -- but was a tyre place just as bad .
  5. lol
    Dec 2006
    Newport South Wales
    lol. or try taking a bigger run up.
    Oct 2005
    Looks like it's time to get that drill out then. There are methods for removing threaded screws some of which may work on bolts, but I'm not sure.
    You could try hammering a smaller socket onto the bolt - it all depends how brave you're feeling.
    Or do as Sean says and take a bigger run up
    Jan 2006
    PRESTON, LANCS
    Quote Originally Posted by sean red i View Post
    Hey -- wonder what would happen if i went out -- parked in a car park - let the tyre down - and called out the AA to change the wheel !!.
  8. A A
    Dec 2006
    Newport South Wales
    if you got the cover ring them. you cant get the wheel off. you have broken down, if you dont ask you dont get,
    Dec 2006
    If the AA cant get the wheel off.. all they will do is recover you home or take you to a local garage for repiars depening on your level of cover..
    RicKT
    I'd be phoning the company who did it in the first place and telling them to get it sorted. They were the last to touch it after all...
  1. Upper hub bolt - siezed?
    By vwmark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2008, 05:59 AM
  2. Removing clamp bolt from front suspension
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-07-2007, 11:37 PM
  3. Help !! Can't get pinch bolt out of clamp
    By SteveRW in forum Passat - Archive Topics
    Last Post: 03-03-2007, 06:52 PM
  4. A4 Rear Bulb- bolt doesn't come out??
    By lindag in forum Audi A4 - Archive Topics
    Last Post: 16-11-2006, 03:00 AM
  5. bolt pattern
    By stuvette in forum Chat - Completely Off Topic
    Last Post: 05-06-2006, 09:30 AM
