Thread: Vag com fault code 1.8t a4
  1. Vag com fault code 1.8t a4
    Oct 2006
    bedfordshire
    Hi Can anyone help
    Put may car into the garage with the engine light on and was told the cam chain tension was faulty.
    I had the head gasket go have rebuilt the top the end and replaced the cam chain and tensioner.
    Engine is running great but after about 30 miles a am getting a fault code
    coming up clear it and another 30-40 miles its back again.
    CODE IS RELATED TO THE CAM SENSOR AND SPEED SENSOR
    IS THIS A GARAGE JOB TO GET THEM RESINKED.
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8E0 906 018 B
    Component and/or Version: 1.8L R4/5VT 0004
    Software Coding: 11501
    Work Shop Code: WSC 10001
    Additional Info: WAUZZZ8E12A057318 AUZ6Z0A0119801
    1 Fault Found:
    17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    P1340 - 35-00 - -
  2. Re: Vag com fault code 1.8t a4
    Oct 2005
    Possible Solutions
    * Check Timing Belt/Chain installation
    o Use Measuring Value Blocks (MVB) to Check Timing Chain
    * Check/Replace Camshaft Position Sensor (G40)
    * Check/Replace Engine Speed Sensor (G28)
    http://wiki.ross-tech.com/index.php/17748/P1340/004928
  1. vag com error code any ideas
    By MCCLATCHIE in forum VCDS - General Questions
    Last Post: 05-06-2010, 09:17 PM
  2. First Auto Scan on Allroad......
    By djl78 in forum VCDS - General Questions
    Last Post: 23-09-2008, 03:22 PM
  3. Temperature sensor Audi A4 (03) 1.8T engine code BFB
    By chris_ahern in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2007, 08:14 PM
  4. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
  5. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
