Thread: RESOLVED: A6 Rear light cluster ( 07)
Page 41 of 42 FirstFirst ... 3139404142 LastLast
Results 401 to 410 of 420
  1. Re: RESOLVED: A6 Rear light cluster ( 07)
    Feb 2009
    Glasgow UK
    Quote Originally Posted by EssexGonzo View Post
    I was behind a misty lighted C6 this morning. A black 2.7tdi with reg plate beginning T1 ... if you're reading. Resisted the urge to jump out and spread the word.
    Ahh Gonzo, you're a better man than me, I woulda jumped out and gave them the spiel to assist them with clear brake lights moving forward, so to speak...lol
    Nice to see a few have picked this up though and applied the fix, haven't seen many in a while now
    Jim
  2. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jul 2008
    Lisburn
    15 Post(s)
    I too had the watery tail lights, i have been able to cure the problem without the need to drill holes.
    the watre has to be getting in somewhere and mine only watered up after rain or a wash, therefore for me it was ingress more than condesation. reading all these posts I had resigned to the fact it was separation of the lens to the back of the light.
    However i noted the grey gasket was damp when i pulled the light to drill the holes, not being keen on this fix as it exposes the contacts to humidity i though i would try one last thing.
    This was a couple of months ago and i have seen some bad weather since and not one misty lens, the cure, remove the grey gasket a good dollop of Vaseline around it and re-insert...
    worked for me, worth a try before getting the drill out...
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: RESOLVED: A6 Rear light cluster ( 07)
    Mar 2011
    Clitheroe, England
    11 Post(s)
    The other day I lost all bulbs in the off side rear cluster. It was the day after I gave it a good jet wash, but that's the first time the problem has occurred since drilling the holes. I may try the Vaseline round the edge of the grey plug as a double precaution.
    Sent from my HTC One M9 using Tapatalk
    The Only Way Is A6!
  4. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jul 2008
    Lisburn
    15 Post(s)
    Bit of an update, i had to split the light again for a blown bulb and the water returned.
    I removed the lights and dried them out over the good weather. this time when the grey gasket was removed i noted it was very flat here and there so i left them out (same as drilling holes?!?!).
    I have ordered 4mm rubber cord to replace them with. I was also thinking of inserting a bag of desiccant when i put them back together..
    the worry is if there is not enough give in the rubber will the units close?
    Stewart
  5. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jan 2018
    Podgorica
    I cant see pics. I`m registered on forum. Can anyone help me, how to see pics to drill holes. I have A6 2006 with led`s, tried everything, and no luck. Drill is my last hope. :-(
  6. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jul 2008
    Lisburn
    15 Post(s)
    No need to drill I simply removed the foam gasket dried lights in sun for an hour or 2 been fine since...
    I never bothered with the rubber as removing the foam seems to have done the trick.
  7. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jan 2018
    Podgorica
    Thank you. I'll try that.
  8. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jan 2018
    Podgorica
    Yeterday i removed gaskets from clusters and dried them out. This morning i checked them, they still clear! Is it possible? I worked so hard to seal them up, but moisture was always return next morning. When i will to wash my car with pressure washer, would water go inside the cluster? Now its totally opened.
  9. Re: RESOLVED: A6 Rear light cluster ( 07)
    Dec 2017
    Scotland
    Hey guys, I'm wondering what foam gasket you're on about exactly. Would you be able to take a picture for me please to show exactly what you removed and dried. I've unfortunately got the problem on both clusters as when changing my bulbs I had to drain the water and dry them thoroughly but unfortunately it's came back.
    Regarding the drill photo, I'll post it below:
  10. Re: RESOLVED: A6 Rear light cluster ( 07)
    Jan 2018
    Podgorica
    Gasket is between cover, where are bulbs, and rest of housing. I dried clusters after removing the cover with bulbs.
    Sorry, cant send you picture. I put them tougether and monted it back on car.
    Only thing is, what happens when it rains, or when i wash car with pressure washer? For now, moisture/fogging is gone. :-P
  1. Rear Light Cluster
    By algarve in forum Golf MK7 - 2013 - 2019
    Last Post: 19-04-2013, 06:52 PM
  2. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  3. A6 Rear light cluster
    By JimC64 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-03-2009, 08:54 PM
  4. Question Rear Light Cluster
    By mdjsa3 in forum Audi A3 - Archive Topics
    Last Post: 19-09-2008, 10:53 AM
  5. rear light cluster
    By glen poole in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2008, 06:47 PM
