Thread: RESOLVED: A6 Rear light cluster ( 07)
Page 32 of 42 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 419
  1. Re: A6 Rear light cluster ( 07)
    Apr 2012
    Wirral UK
    Hi guys did the drill fix about 8 months back.... worked great and still working! Cheers
  2. rear light cluster removal
    Dec 2013
    Liverpool
    7 Post(s)
    Trying to sort out condensation & bulb issue, Is it just one nut & a bit of brute force to remove the cluster, struggling to get it out.
  3. Re: rear light cluster removal
    43 Post(s)
    One long blackish nut and then pull it out. There are also two locating tab things on the wing side.
    Your manual will give the procedure.
  4. Re: rear light cluster removal
    Dec 2013
    Liverpool
    7 Post(s)
    Yes 1 nut & "persuasion", Pre-facelift has LED brake lights fitted, but still getting condensation & keeps throwing up rear light, fog light & indicator bulb all out.
  5. Re: rear light cluster removal
    43 Post(s)
    Only had LED brake light if Highline clusters have been retrofitted or you have Xenons.
    Check the bulb holder contacts and bottom of the bulbs for corrosion. I left a link on one of your other light related threads.
  6. Re: rear light cluster removal
    Dec 2013
    Liverpool
    7 Post(s)
    yes cheers Chris, I think I know what the connection failure is, Audi have used what looks like a Zinc rich material for the connector "strips" where as the zinc is supposed to resist corrosion with the moisture issues in the light cluster this causes a powdery white residue to form on the surface causing a poor connection. anyone have any thoughts on this???
  7. Re: rear light cluster removal
    Mar 2009
    Essex
    Quote Originally Posted by peter goble View Post
    Only suggestions from me are, in this order, sands down the contacts, drill some nice holes and see what happens. If that doesn't work, get a new bulb holder rather than whole new cluster.
    Sent from my HTC One using Tapatalk
  8. Re: rear light cluster removal
    Aug 2013
    Carlisle Cumbria
    8 Post(s)
    Yes 1 nut & "persuasion".
    When I took my R/H cluster out, I'm sure it hadn't ever moved since it left the factory. There was a lot of stiction between the pegs on the cluster and the bungs which locate it. I would have tried some rubber / nylon lubricant had it not come out eventually. Drilling the holes fixed the condensation issues.
  9. Re: rear light cluster removal
    Jun 2008
    London
    On my a6 I undo the nut on the inside, push on that with the back of the screwdriver as well as trying to ease out using an one plastic card (like credit card but one that I don't use! ). Have to move it back, so following the line of the car rather than pulling outwards. Takes a while as well as some 'wiggling'!
    Sent from my GT-I9300 using Tapatalk
    2008 A6 2.0TDi SE Avant
  10. Re: rear light cluster removal
    Mar 2009
    Essex
    Quote Originally Posted by clintyboy12 View Post
    Snap. Instead of the credit card (life would end if I snapped it) I use a wallpaper scraper covered in insulation or duct tape.
    And lots of wiggling plus a soft landing for when the cluster inevitably comes shooting out.
  1. Rear Light Cluster
    By algarve in forum Golf MK7 - 2013 on
    Last Post: 19-04-2013, 06:52 PM
  2. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  3. A6 Rear light cluster
    By JimC64 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-03-2009, 08:54 PM
  4. Question Rear Light Cluster
    By mdjsa3 in forum Audi A3 - Archive Topics
    Last Post: 19-09-2008, 10:53 AM
  5. rear light cluster
    By glen poole in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2008, 06:47 PM
