Thread: Failed emissions test
  1. Failed emissions test
    I have a 1995 A6 with ABK engine which has just failed its fast idle emissions test. The reading for Co should be equal or less than .30% but its showing .74%. Mechanic says I need a new cat. It passed the natural idle test, only failed the fast idle.
    I dont want to pay for a new cat if there is another reason for the high reading at higher revs, would appreciate any feedback.
  2. Wink Re: Failed emissions test
    North Hampshire
    Hi. I had a similar situation 2 weeks ago with my AEB engine. Failed on high HC at normal and high revs. Garage recomended:
    (a) lambda sensor change
    (b) new CAT
    It passed the retest (just!!) after a lambda sensor change.
    Check/test your lamda sensor first (cost is about £65) before changing your CAT as CAt is more expensive. Good luck
  3. Re: Failed emissions test
    Mar 2008
    Just Cumbria now.
    An Italian Tune up just before testing may help also by shifting some of the crud etc.
    Try going for a good run (20 miles +) revving the engine hard once warm to near the redline.
    Obviously this is on your own head and if you feeel that your car won't take it, don't do it.
    HTH.
    Nothing to see here, move along..
  1. Failed Emissions
    By alexmcc in forum Golf MK3 - 1993 - 1999
    Last Post: 15-03-2008, 05:26 PM
  2. Need HELP! with emissions for re-test Thursday
    By b5passat99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2008, 03:28 AM
  3. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  4. A4 20v non turbo ADR 1998 emissions failed
    By bullet in forum Archive posts
    Last Post: 24-03-2007, 11:01 AM
  5. A4 20v non turbo ADR 1998 emissions failed
    Last Post: 12-03-2007, 12:00 PM
