Thread: Pre wired Cd Changer connector location
Results 1 to 8 of 8
  1. Pre wired Cd Changer connector location
    benw1984 Guest
    i have an alphine aftermarket cd changer that i would like to put into my A4. the headunit is a Chorus cassette palyer.
    With the changer being an aftermarket one do i need special interface cable for it to work? also does anyone know whether there should already be a cable somewhere in the car for me to connect to and if so where would it be? or do i need to plug directly into the back of the headunit?
    Any help would be very much appreciated.
    many thanks.
    Benw1984
  2. Re: Pre wired Cd Changer connector location
    Aug 2007
    Some cars do have the wiring, some don't. Mind certainly doesn't. I bought a cable to connect the multichanger in the glovebox to the Chorus cassette unit for about £15 of eBay.
    If the wiring isn't behind the glovebox (5 hex bolts to remove easily and look, you will need either a glovebox with the hole in it for the CD unit or to cut a hole in it yourself) it might be in the boot on the left, I think. Search on here, you'll find an answer - probably the original thread I posted about 2 years ago when I bought the multichanger!
  3. Re: Pre wired Cd Changer connector location
    Aug 2007
  4. Re: Pre wired Cd Changer connector location
    benw1984 Guest
    Thank you Hagis i will have a search around and have a look at your earlier thread.
    One other thing though... where would i find out what cable i need? i found one for £50 on the web (which i thought was a bit pricey) but it didn't have a number or specific name to be able to look on ebay, it just said it would do the job.
    Many thanks,
    Ben1984
  5. Re: Pre wired Cd Changer connector location
    Aug 2007
    I can't remember the name of it and I can't find the thread on here where someone recommended it to me (you may want to have a look yourself). If I can get to the lead (which I've a horrible feeling if buried under a mound of junk in the spare room) I'll try and get a photo.
    Unless someone else can say what it is?
  6. Re: Pre wired Cd Changer connector location
    benw1984 Guest
    Thanks again Hagis. Dont worry about digging it out, i will do some more research on here and the net. It might even be worth a quick phone call to a car audio centre to see if they can tell me what it is.
    thank you.
    regards,
    Ben1984
  7. Re: Pre wired Cd Changer connector location
    Dec 2006
    I think.. (well they used to do) Halfords of all places did the Audi/VW headunit plug to a universal auto changer.
    Rick
  8. Re: Pre wired Cd Changer connector location
    benw1984 Guest
    Thanksn Rick.... i will call in over the weekend and check it out!
    many thanks
    Benw1984
  1. Anyone give me some help on CD Changer
    By zx013299 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-09-2017, 09:23 PM
  2. CD changer
    By devsgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2008, 05:07 PM
  3. CD changer problems
    By V5_170Mk4driver in forum Golf MK4 - 1999 - 2004
    Last Post: 13-01-2008, 09:27 PM
  4. Will Gamma radio operate CD changer?
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2007, 01:02 PM
  5. 1997 Passat CD changer
    By sbgsxr6 in forum Passat - Archive Topics
    Last Post: 05-10-2006, 12:32 PM
