Thread: Electric Window Fault
  1. Electric Window Fault
    please help i got up this moening and neither of my electric widows work i can here a click in the respective door when the buttons are pressed but no movement grinding or anything what could be the problem?
    thanks in advance
  2. Re: Electric Window Fault
    corroded wire in the loom under passenger seat red and white wires 3 join together all working now just cut away blue corroded copper ri join and solder alls great now very easy to do
  3. Re: Electric Window Fault
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by ant130979 View Post
    Ah, the dreaded Passat flood strikes again.
    Have you checked your Plenum chamber recently?
    Nothing to see here, move along..
  4. Re: Electric Window Fault
    Oct 2009
    Northampton UK
    I have a similar problem with my offside rear window - Passat 2000 V5 est. - it clicks but no attempt at movement. I have checked the wiring where it comes thro the door pillar and there is no power on the Red/White. Your post says under the passenger seat, I guess thats front ? If so does it mean taking out the seat, I've got Haynes manual and it says I need a special cable to ground the seat air bag if i take it out - is that beyond a diyer? I've read the posts about water in the car and I don't think I've had that but its over nine years old so who knows.
    thanks
  5. Re: Electric Window Fault
    Norfolk
    Never touch the air bag wires or connect anything to them.. Disconnected battery. Wait 10 minutes. Unplug air bag connector under seat, remove seat. Wires under carpet, passenger front. Unwrap the wires and look carefully for corrosion especially at soldered joints. Easy diy job.
  6. Re: Electric Window Fault
    Oct 2009
    Northampton UK
    Quote Originally Posted by martin1810 View Post
    Thanks Martin, much appreciated.
  1. Question Caravelle electric window fault
    By steve1561 in forum New Member Introductions
    Last Post: 27-11-2008, 06:23 PM
  2. Polo 6N2 electric window fault
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2008, 10:11 AM
  3. electric window fault
    By scott007118 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2008, 01:55 PM
  4. Electric Window Fault
    By beltaine in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-10-2007, 02:08 PM
  5. electric window fault
    By vw_craig in forum Golf MK3 - 1993 - 1999
    Last Post: 19-10-2007, 06:03 PM
