Thread: (!) flashing
Results 1 to 9 of 9
  1. (!) flashing
    Feb 2009
    Hi everyone i was driving down the road and all of a sudden the (!) light has started to flash on the dash board. However what i find odd is that the audi coupe (94) still drives completely fine.
    I checked the rad levels, power steering fluid and the brake fluid and they are all fine.
    I have just recently changed the spark plugs, HT leads, ignition coil and dizzy.
    Could the engine management system need to be set or is it something else?
    Andy
  2. Re: (!) flashing
    Jan 2009
    towcester northants
    if its the red light its either low on brake fluid or the pressures of the brake booster are low
  3. Re: (!) flashing
    Feb 2009
    The brake fluid looks find, could i ask what a brake booster is?
    cheers
    Andy
  4. Re: (!) flashing
    Jan 2009
    towcester northants
    some of the early coupes had a hydrualic pump(part of pas pump) that worked the brakes instead of a servo they had a accumalator bolted down on the n/s of engine which was instead of a servo after running switch off and you should get 20-25 pumps of the pedal before it goes hard these used to fail
  5. Re: (!) flashing
    Feb 2009
    N.Wales
    mines doing exactly the same thing trhis mornig, just sometimes it stoped for a second? strange
  6. Re: (!) flashing
    Feb 2009
    N.Wales
    have you cheked your power steering fluid level, i cheked mine and toped it up and now the light dosent come on!
  7. Re: (!) flashing
    Gwent
    just for information, the power steering system and the hydraulic brake assist use a tandem pump i.e. two pumps in one. The fluid used in this system must be hydraulic mineral oil NOT pas fluid. The Audi spec for the oil is g002000 which has now been superceded by G004000.
    If pas fluid is put in this system, it causes leaks and other failures, none of them cheap to fix!!
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  8. Re: (!) flashing
    Mar 2009
    hi my 2.6 v6 did the same thing from cold.Or when it had been stood for a few hours. I would try changeing pas fluid,it worked for me for a while. Still flashes every so often but only for a second or two. Used to flash for 30 seconds or so before. Will change it again and let you know how it goes.By the way use o.e fluid. hope this helps.
  9. Re: (!) flashing
    Jan 2010
    gloucester
    snap had same problem turned out to be low level in the power steering fluid and like said about use mineral oil not normal pas fluid also there is a sender that slides out of the brake fluid resivoir underneath these can fail too easy to change
  1. OIL flashing on odo
    By richrox75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-07-2008, 05:49 PM
  2. flashing climotronic
    By andy pen in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-03-2008, 10:24 AM
  3. Indicators not flashing!
    By misswhiz in forum Audi A3 - Archive Topics
    Last Post: 22-06-2007, 11:05 AM
  4. flashing symbols?
    By dieselal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-05-2007, 08:11 PM
  5. flashing oil light
    By arfon in forum Audi A4 - Archive Topics
    Last Post: 27-04-2007, 12:23 PM
