Thread: A4 2004 how to remove the front Door panel
Results 1 to 10 of 11
  1. A4 2004 how to remove the front Door panel
    Mar 2009
    Does anyone know how to remove the Driver side front door panel
    on a A4 2004 TDI. I do not know what has happened, but there is a horrid
    vibration noise coming from within. It's Like a loose washer vibrating ...
    Any help really appreciated...
    THANKS....
    kjc1
  2. Re: A4 2004 how to remove the front Door panel
    Feb 2009
    Firstly there is a screw underneath - you have to remove this,
    then the tweeter speaker cover needs to be removed and the screws under this undone.
    lift out the switches for the windows (screw driver under boot end and carefully lift). undo the screw under this
    remove the wooden trim at the top of the door (pull gently from the "rear of car" end). Undo the screws under this
    pull from bottom moving around edges to eisengage clips, there are several!!
    lift panel up to disengage
    I would suggest you get a copy of ELSAWIN off ebay as that has the diagrams etc.
    Let me know if you need any more info,
    Walter.
  3. Re: A4 2004 how to remove the front Door panel
    Sep 2007
    Windsor
    Sorry, I have to disagree with wmccann - but not entirely!
    1) Remove screw from the bottom of the panel in the centre (as already described).
    2) Prise out cover from just below the armrest and remove the two screws
    3) Remove trim from above the door release handle that runs the length of the door by pulling from the front edge and sliding the trim forward.
    4) Remove the 4 screws from behind the trim just removed in step 3.
    5) Prise the panel away from the door and lift panel up once clips are disengaged (as previously described).
    No need to remove tweeter grille or window switches.
  4. Re: A4 2004 how to remove the front Door panel
    Feb 2009
    Apologies, what I put was for the A4 Cabriolet,
    Walter.
  5. Thumbs up Re: A4 2004 how to remove the front Door panel
    Mar 2009
    Thanks Guys ......that did the trick nicely. Found the source too
    KJC
  6. Re: A4 2004 how to remove the front Door panel
    Aug 2008
    Somerset
    If you don't mind me asking... how long did it take you? I've got an annoying rattle in the front passenger door that I'd like to sort out...
  1. how to remove a door panel on Seat Alhambra
    By topanhodgson in forum Alhambra
    Last Post: 20-04-2013, 02:36 PM
  2. Please Help how to remove rear door trim panel
    By pendle wizard in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-02-2009, 12:18 AM
  3. Please Help How to remove rear door panel?
    By mikka528 in forum Toledo
    Last Post: 01-10-2008, 08:42 PM
  4. how to remove a door panel from a mark 4 golf
    By garrygolf1.6 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-11-2007, 06:31 PM
  5. Touran - remove driver door panel
    By rmcleod1576 in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2007, 03:37 PM
