hi peeps
i have recently been informed that my turbo actuator is faulty.hence the reason in loss of power.i was just wondering how easy it is to fit these as i know that when you buy a turbo they already come setup as factory setting.the mechanic i used told me that the actuator and wastegates are a common fault on the k03 turbos as the spring gets weak so it cant fully operate.i was also told that there is a slight seaping of oil in the manifold which is also from the turbo and this is quite normal....does anyone no how gospel this is?
