Thread: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
Results 1 to 8 of 8
  1. Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Mar 2007
    I have a Golf Mk4 V6 4Motion, which only remotely unlocks the driver's door. I understand that the car is programmable, in that it can be configured to open just the driver's door with one push of the remote unlock button, then the rest of the car with the second push of the button, or, the whole car with just one push. My car, however, only unlocks the driver's door no matter how many times you press the remote unlock button, or how rapidly. The strange thing is, if you then insert the key into the drivers door lock and turn it twice clockwise, the boot and other door unlock as they ought, plus, the button next to the drivers door handle inside also works as it ought, by locking or unlocking the whole car. It is just the remote operation that will not unlock the whole car! This is the same with both remote keyfobs that I have. Has anyone else experienced this please? Do you have any suggestions as to where I should start looking to 'fix' it?
  2. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Sep 2007
    Shame you haven't had a reply about your problem, because I have exactly the same one! Did you get it sorted in the end? If so - how??
  3. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Aug 2007
    Northern Ireland
    Do you have or know anyone in your area vag-com? Try checking the soft coding for the RCL - possibly someone has reprogrammed in the past to just open the drivers door, or were messing and got the coding wrong. Just a guess.
    I take it has been like this since you got the car, if not then possibly an electrical fault.
  4. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Mar 2007
    I did get an answer to my problem, from another forum. It was suggested that I disconnect my battery, for at least 5 minutes, so that all the fault codes get a chance to delete themselves from the car's systems. I tried it (although I left it for atround an hour - whilst I changed the spark plugs) and hey presto, the remote locking of all the doors was restored. One press for the drivers door, two presses for the passenger and boot. It was as simple and inexpensive as that!
  5. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Sep 2007
    Derby
    I too have just had this same problem and left battery off for 5 minutes and now its works perfect!
    Thanx for the advice!
  6. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Superb, just tried this on my mk4 golf 52 plate and it worked a treat. Saved a trip to the dealer which would have cost 50 quid probably. Thanks
  7. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    Dec 2007
    Belfast
    Reading this post, the first thing that springs to mind is the battery in the remote key fob ??
  8. Re: Mk4 Golf remote unlocking, only working on driver's door, with 1 or 2 keyfob presses!
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thank you Boycie
    Am just fixing a number of issues on my mother's Golf, and whilst it was with the mechanic, the battery went flat. The ability to unlock all doors from a double-press on the key went with it!
    I've just been out, disconnected both battery cables from the terminals and left it for six minutes, and the function was restored after they were re-connected. Thanks!
  1. Golf - Window dropped into driver's side door!
    By Rachel in forum Golf MK4 - 1999 - 2004
    Last Post: 13-11-2007, 09:29 PM
  2. Golf driver's door handle forced (screwdrivered) and broken into
    By Mungler in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-06-2007, 08:01 AM
  3. Passat Remote Not Working
    By k1ng229 in forum Passat - Archive Topics
    Last Post: 08-03-2007, 09:29 AM
  4. Rear passenger left door not locking/unlocking.
    By desgreen in forum Passat - Archive Topics
    Last Post: 21-10-2006, 06:43 AM
  5. Rear passenger left door not locking/unlocking.
    Last Post: 26-07-2006, 06:41 PM
