Thread: broken X relief relay symptoms
  1. broken X relief relay symptoms
    Dec 2008
    Hi there,
    At the weekend my blower; wipers (front, back and washers); heated rear windscreen and fog lights all packed up. I checked on here and was overjoyed to see that it was just the X relay that had gone. So, i bought another, plugged it in, and... nothing. It still doesn't work. Having re-read the original thread, i checked my glovebox light and that doesn't work, either.
    The original thread is here: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=41853
    Also, rather confusingly the relay was located at position 4, not position 8 as stated in the haynes.
    Any help greatly appreciated.
    Cheers,
    Scott Mac.
    p.s. My car is a 89 Mk2 8V GTi, if that helps.
  2. Re: broken X relief relay symptoms
    135 Post(s)
    2042 Post(s)
    If the X contact relay is at position 4, your car is a 1990 model, confirmed by the hazard warning light switch being on the steering column. Do your dipped beam headlights work?
  3. Re: broken X relief relay symptoms
    Dec 2008
    Yep. Dipped and main beams work. And yep, my hazard switch is on the steering column. I guess 1990 is correct as it was registered in Nov 1989.
  4. Re: broken X relief relay symptoms
    135 Post(s)
    2042 Post(s)
    If the headlights work and the relay is a new genuine unit you are down to a fuse box fault as if the headlights work the ignition switch X contact is OK, either that or a wiring fault.
  5. Re: broken X relief relay symptoms
    Apr 2014
    Derby
    30 Post(s)
    I have started a similar thread here - any help appreciated
    Weird electrical issues - CCM, X Relay or Ignition switch
    Current Fleet
    2017 Audi A6 Avant BiTdi
    2017 GT3 991.2
    2008 BMW Z4M Roadster
    2003 Clio 172 Cup
  1. Tiptronic Selector Broken/Stereo Mounting Broken
    By anthonyendsor in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2008, 10:21 PM
  2. Oil pressure relief valve
    By aa303 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-04-2008, 08:56 PM
  3. Symptoms of faulty MAF?
    By FastMan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 04:47 PM
  4. Please help , look at these symptoms.
    By nutter1980 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2007, 02:00 AM
  5. A4 Turbo B5 - A Bit Of Useful Light Relief
    By nick_a4t in forum Archive posts
    Last Post: 10-08-2007, 12:49 AM
