Thread: help please epc light fault code 17961/cambelt
  1. help please epc light fault code 17961/cambelt
    hi the we have a problem with a golf 1.6 azd 2001 its showing a fault code 17961 mainfold sensor/altidude and epc light coming on when reved passed 3000 running rough .I have changed throttle body still the same coil packs.But the cambelt looks a bit loose to me is it possible for this to jump a tooth and still run, the cambelt looks ok but just a tad loose on the front side leading edge towards front car.i just remember reading somthing about this before that the belt and timming putting epc light on any help would be great thanks again
  2. Re: help please epc light fault code 17961/cambelt
    Jan 2009
    towcester northants
    is it a 1.6 16valve engine?
    if so look at the timing belt idlers as the lower idler can fall apart and cause issues
  3. Re: help please epc light fault code 17961/cambelt
    hi yes its a 1.6 16valve with the nightmere azd engine code its strange the lower casing had worn threw from the inside
  4. Re: help please epc light fault code 17961/cambelt
    Jan 2009
    towcester northants
    sounds and looks like the good old lower tensioner let go of plastic roller
    this is so common you are lucky to catch it before letting go and bending valves
    my freinds one let go at 3.5 yrs 22000mls VW wouldnt even contribute to the repair they said it wasnt a common fault
  5. Re: help please epc light fault code 17961/cambelt
    i wonder if this is why this epc light comes on when its reved up
  6. Re: help please epc light fault code 17961/cambelt
    Jan 2009
    towcester northants
    i would say yes as you will get valve overlap and back pressure in the inlet manifold
  1. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  2. Golf 1.8T Fault Code (Engine Management Light On)
    By Silver1.8T in forum Golf MK4 - 1999 - 2004
    Last Post: 08-04-2008, 08:21 PM
  3. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  4. help please!! error code 17961??? anyone??
    By dtwoi in forum Archive posts
    Last Post: 29-07-2007, 12:10 PM
  5. Code 16804- warning light comes on but no fault?
    By paulco62 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2007, 09:35 PM
