Thread: change from long life to regular service regime on A4
Results 1 to 10 of 12
  1. change from long life to regular service regime on A4
    Mar 2009
    Does anyone know how to change from the long life variable to the fixed interval, service regime.
    I have the 1.9 tdi 2005 diesel with 19,500 on the clock. genuine as excellent condition.
    I have purchased the
    Super VAG 5053 DIAGNOSTIC OBD 2 Scanner VW FAULT CODE
    and expect it in the post soon.
    Any help greatfully appreciated.
    Dave
  2. Re: change from long life to regular service regime on A4
    Mar 2007
    Lancashire
    Simply start servicing the car regularly. My car was on longlife when I bought it from a mate. Ditched longlife right away after a poor condition oil filter was revealed. When I did mine I simply reset the service indicator and it defaulted to 360 days or 10k miles. I'm sure that is the norm if reset manually.
    I now drain the oil and change filter every 6 months. Every 12 months for pollen, air filter and approx 18 months for fuel filter.
    Brake and clutch fluid replacement every 18 - 2years. I check under the car when performing oil drain, check hoses and look for leaks.
    Every spring the brake caliper are removed all round and checked for wear and free movement with a clean up. Rid the winter salt.
    Other than the timing belt most things are straight forward. I've serviced my A4 for the last 4 years and it runs sweet!!
    Marco
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  3. Re: change from long life to regular service regime on A4
    28 Post(s)
    697 Post(s)
    To be correct the dash needs to be recoded for fixed interval servicing so that the warnings come up correctly. This can be done with VAG-COM or something similar.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  4. Re: change from long life to regular service regime on A4
    Mar 2007
    Lancashire
    Ah ok. I may have just been lucky. I did change in vagcom at the time to 182 days or 5k, which has worked nicely.
    Oh and not to mention correcting the over easger MPG DIS!! It was 15% high!!
    Re-map by more-bhp.
  5. Re: change from long life to regular service regime on A4
    28 Post(s)
    697 Post(s)
    If you have a full version of VCDS 805 ish you can go into the coding and a helper screen will show you if it needs recoding to fixed intervals.
  6. Re: change from long life to regular service regime on A4
    Aug 2008
    I am coming off long life also. It is saying I have about 3 months left but I am going in for the major service and will do every year
  7. Re: change from long life to regular service regime on A4
    Mar 2009
    Quote Originally Posted by Marco34 View Post
    Hi there
    Please be kind enough to enlightem me as to how you did it?
    I just bought the VAG 5053 so I can read and set the blocks and codes etc.
    I just dont see from the thousands of blocks which is the ones to change.
    Dave
  8. Re: change from long life to regular service regime on A4
    Mar 2007
    Lancashire
    I can give you details as I made notes in excel. So many adaptions and codes that it's best to keep a track. I'll get them from my laptop at home and post details tonight. send me a PM with your'e email (if you like) and I shall send you some handy word docs I've got also. Shows you what you can do with VCDS>
    Re-map by more-bhp.
  9. Re: change from long life to regular service regime on A4
    Mar 2009
    Marco
    I dearly hope you can help me through this.
    I am Tech savvy but dont know how to interpret the code and blocks without a guide as to what block is which. If you have some help hints I would be ever in your favour.
    Dave
  10. Re: change from long life to regular service regime on A4
    Mar 2009
    Sorry forgot to add my email
    Its
    dvd11223344@yahooDOTcoDOTuk
    Last edited by onzarob; 09-03-2009 at 12:26 PM. Reason: Stop your email becoming a spammers dream !!!
  1. Question Long life Service
    By nunncm in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-02-2009, 05:32 PM
  2. Question Long life service???
    By jayegee16 in forum Chat - Anything with wheels
    Last Post: 19-01-2009, 12:51 AM
  3. Long life service... or not?
    By Sqwim in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-11-2008, 09:02 PM
  4. Long Life Service
    By Irri_Tant in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 10:33 AM
  5. Long Life service
    By bora(ing) nick in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-01-2007, 03:33 PM
