Thread: Original Spec Front Fog Lamps
  1. Original Spec Front Fog Lamps
    Mar 2009
    Can anyone shed some light on how the (optional) front foglights would have been wired up on my 1998 Passat?. I was given two new headlamp units to replace my original faded opaque ones, and they are for front fogs (the main beam has a H4 60/55w bulb so the dipped 55w part acts as the fog) so I thought I would fit them. The new units have 6 pin female sockets, so do the original male 6 pin plugs, and I have fitted the 2 stage pull lighting switch for front & rear fogs. Can't get them to work, there is power leaving the switch (yellow wire) but none arriving at the 6 pin socket. Should there be another relay?
  2. Re: Original Spec Front Fog Lamps
    Norfolk
    You need the foglight relay. Should be position 10 in the relay box.
  1. Lower front arm balljoint separator - spec?
    By wanstronian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-01-2009, 10:58 AM
  2. Question Late Spec Front Lights
    By A3Quattro1985 in forum Audi A3 - Archive Topics
    Last Post: 06-10-2008, 06:33 AM
  3. T5 Fog Lamps
    By spyder in forum The Commercial Range
    Last Post: 23-06-2008, 09:29 AM
  4. Retrofitting front fog lamps
    By Lima Foxtrot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-09-2007, 06:55 PM
  5. Original spec A3 remote keys
    By erisaman in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-08-2007, 09:00 AM
