Thread: intermittent dashboard instrument failure
  1. intermittent dashboard instrument failure
    Feb 2009
    south west england
    help needed please? speedo/odometer/petrol gauge goes on strike intermittently. need to know how hard to fix as amateur or do i need mechanic? thanks if you can help.
  2. Re: intermittent dashboard instrument failure
    Nottingham
    Pull fuse no.15 and leave it out next time the fault happens. If that brings the dash back, pm me or post back and I'll explain the fix/concequences.
    Quote Originally Posted by msgoldilocks View Post
  3. Re: intermittent dashboard instrument failure
    Jul 2009
    london england
    hiya. i've just had same thing re intermittent dashboard failure. garage "reset parameters" yesterday but car did it again briefly then worked again. not tried the fuse thing yet - do you mean leave use out completely and drive around without it? and what could be consequences be. wondered if it could also be a loose connection in engine bay following some other work there recently re abs and engine management thanks for help
  4. Re: intermittent dashboard instrument failure
    Jul 2009
    Glasgow UK
    Hi Greg.
    Pulling out fuse 15 works, but I would be grateful if you could post details please of the fix for this, (apart from replacing the cluster and getting it reprogrammed for the ecu/immobilizer....).
  5. Re: intermittent dashboard instrument failure
    Sep 2016
    Peterborough
    Hi Greg (or anyone else with a solution)
    I came across a thread you posted on back in 2009 about intermittent cluster failure in a VW MK4 Golf/Bora. I'm experiencing this issue (rev, speedo, temp, fuel gauge freeze or fail sometimes and other times work perfectly).
    Before I send off the cluster to attempt a rebuild, I'd like to find out if there's anything else I can try. I think you mentioned pulling out fuse 15 as a test, but that's as far as the discussion went.
    Any help would be appreciated.
    Many thanks!
    Quote Originally Posted by greg123 View Post
  1. Intermittent instrument panel failure
    By i_kersey in forum Polo - Derby - Lupo - Fox
    Last Post: 09-07-2009, 11:20 PM
  2. Instrument power failure
    By mogman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2009, 03:46 PM
  3. Golf Mk 4 Intermittent Fault On Dashboard:
    By rpbaggy in forum Golf MK4 - 1999 - 2004
    Last Post: 08-02-2009, 09:18 PM
  4. sharan instrument failure
    By aerobobcat in forum Touran - Sharan - Caravelle
    Last Post: 13-06-2008, 09:18 AM
  5. A3 instrument cluster failure
    By chrislodge99 in forum Archive posts
    Last Post: 18-09-2006, 08:53 PM
