Thread: Nasty transmission noise!!
  1. Nasty transmission noise!!
    Feb 2009
    Hi Folks
    Hoping someone can help with a problem I have with my beloved 1.8s Auto.
    It's only done 45k, but now after about ten miles makes a horrible grinding noise from the transmission.
    Auto box changes smoothly upto and after the noises start.
    Seems OK off load, the noise is not related to a road speed component but rises and falls with throttle setting, you know what I mean, sort of clutch dying! Torque converter?
    Regards
    Mark
  2. Re: Nasty transmission noise!!
    Jan 2009
    towcester northants
    a good old Munn and Chapman car
    sounds like gearbox failure
    there used to be a good transmission specialist in High Wycombe but cant remember their name sorry
    the gearbox you have use to leak the oils between diff and auto section due to a seal and this would cause the diff /pinion bearing to wear causing a whine under load but not when off accelerator
    i know its not any help but i might of done the pdi on this car when it was new
  3. Re: Nasty transmission noise!!
    Feb 2009
    Hi, your not wrong, it is a Munn & Chapman car thats now made it's way West Sussex.
    Thanks for that info even though it could spell doom for the poor old 80, shame, its a lovely car in incredible condition.
    Don't tell the wife but will probably hide it at the back of the barn until a diff/box turns up.
    Once again thanks for your input.
    Do you think it's worth converting to manual?
    Mark
  4. Re: Nasty transmission noise!!
    Sep 2007
    plenty of them about but realisticly whats it worth to you a hell of a lot to someone else ??
    cheers Raj
  5. Re: Nasty transmission noise!!
    Jan 2009
    towcester northants
    hunt the auto trader or yellow pages to get quote from auto box specialist you may be suprised
  6. Re: Nasty transmission noise!!
    murphyv310 Guest
    Hello.
    My old "E" reg 80s had the very same fault and eventually lost all drive but mine was 187,000 miles, cracking old car though and before the box went duff the only fault other than servicing was a set of valve seals.
    I would keep it & look for a box or sell it to me for a nominal sum
    Good luck.
    Trevor
  7. Re: Nasty transmission noise!!
    Feb 2009
    Thanks for all the encouragement chaps, the 80 is now tucked away in the barn and I'm starting to hunt round for a solution.
    Unfortunately there's about 12 other semi classic cars including Midgets, Morgans, Mk1 Minis, Renault 4s, Land Rovers ETC, so do have my work cut out.
    Having said which, my son has just appeared reporting noise from CV on his MK2 Golf GTI, I'm doomed.
    My village garage has less cars to look after!
    All my wife says is "why don't you get an Audi A2 like mine, it never goes wrong". Thanks love.
    Thanks again chaps, will keep you posted.
    Mark
  1. Please help - Noise in transmission
    By Ian Lane in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-01-2009, 12:16 PM
  2. transmission noise
    By 80quattro1987 in forum 80 - 90
    Last Post: 13-12-2007, 03:35 AM
  3. nasty place for plugs
    By art in forum Audi A3 - Archive Topics
    Last Post: 05-08-2007, 04:45 PM
  4. noise in 1996 Golf 1.6 transmission
    By whugh@online.no in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2007, 08:25 PM
  5. 1996 golf 1.6 100hp with transmission noise
    By whugh@online.no in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-05-2007, 11:09 AM
