Thread: Engine undertray fasteners
Results 1 to 9 of 9
  1. Engine undertray fasteners
    Aug 2008
    Somerset
    Two of the fasteners attaching the engine undertray on my B6 Avant have disappeared. They're the ones holding the small deflector that sits ahead of the offside front wheel, causing it to droop and giving the whole tray a lopsided sag on that side.
    Does anyone know the relevant part number, by any chance?
    I'm contemplating a temporary ziptie bodge of some kind, but it'd be nice to get it properly sorted. My old Octy developed a saggy undertray which grounded more and more frequently, resulting in its eventual disintegration. I'd like to avoid that, if possible...
  2. Re: Engine undertray fasteners
    Sep 2008
    6 Post(s)
    Not unusual for the fastners to vibrate themselves free. I started using nylon zip-ties. They're very strong and if you're servicing the car yourself, you simply cut and replace them.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  3. Re: Engine undertray fasteners
    Mar 2007
    Oxfordshire
    Yes about 4 of mine have disappeared - I asked the garage to replace them on Friday - must look to see if they have. Tried to find the part number but failed, you may need to phone Audi...can you post the number when you have!
  4. Re: Engine undertray fasteners
    Aug 2008
    Somerset
    Zipties sound like a great solution... except having had a closer look I can't see how to make them work in this case. For each missing fastener there's essentially a single hole. A ziptie needs an entry and an exit hole to make a loop... unless I'm missing something blindingly obvious
  5. Re: Engine undertray fasteners
    Aug 2008
    Somerset
    Quote Originally Posted by randall977 View Post
    I'll let you know if I find the answer!
  6. Re: Engine undertray fasteners
    Mar 2007
    Lancashire
    Snap, I'm missing a few. They don't seem critical but are the ones near the arch. Would like to get some. I've used ties in the past too...
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  7. Re: Engine undertray fasteners
    Dec 2014
    9 Post(s)
    Seems like this never got solved, can anyone advise on part numbers for fasteners please?
    cheers ian
  8. Re: Engine undertray fasteners
    Dec 2014
    9 Post(s)
    Seems like the following numbers might be relevant for the various different ones holding the tray on depending whether it’s
    -wheel arch
    -bumper
    -strut shared with gearbox cover or at front near bumper
    but I haven’t figured out which is which
    8E0805121A
    8E0805121/8D0805121
    8E0805121B
    and some Have a rubber washer which may be
    EDIT:
    I have figured out that 8E0805121A is the one at the front edge holding the bumper to the belly pan. The corresponding “nut” for these is lower profile
    8E0805960 And seems a bit rarer/expensive on eBay but i think I’ll try to fashion something from one of the “normal” Ones that go with
    8D0805121
  9. Re: Engine undertray fasteners
    Apr 2014
    SW London / Surrey
    126 Post(s)
    See if these seem right as well:
    Spreader river (little panel in front of wheel arch): N0385491
    Grip pin: 8D0805121 (...B suffix for black)
    Washer behind varous connectors: 4A0805137
    1 1 0
  1. Engine Undertray
    By polowner in forum Polo - Derby - Lupo - Fox
    Last Post: 06-02-2009, 03:09 PM
  2. Engine Undertray
    By mattyc94 in forum 80 - 90
    Last Post: 12-01-2009, 11:35 PM
  3. Engine Undertray Ripped off
    By The Whittys in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-08-2008, 09:47 PM
  4. Engine undertray
    By marmot in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 10:24 PM
  5. replacement engine undertray
    By desgreen in forum Archive posts
    Last Post: 30-01-2007, 11:25 AM
