Thread: Fuel Lines
Results 1 to 10 of 11
  1. Fuel Lines
    Feb 2009
    bedfordshire
    After getting my new 19 year old coupe in at work tonight and up in the air I happened to notice one of the fuel lines was rotted through to the point that it was moist with fuel all the time, carried out a temp repair on it but was wondering where I can get fuel lines for cars as old as this nowadays as can find nowt on the internet.
    A question that is in my head is that I have seen fuel high pressure rubber hose for sale, is this any good to run from the back to the front of the car or does it have to be the metal pipes ? ta
  2. Re: Fuel Lines
    1840 Post(s)
    It depends on the injection system, medium pressure electronic or high pressure mechanical. On the electronic injection you can get away with replacing the lines using nylon thin wall or rubber but not on K-Jet.
  3. Re: Fuel Lines
    Feb 2009
    bedfordshire
    yea its the K jet, I know it runs really high pressure but is right the way from the tank at that pressure then as noticed there has been a bit of it replaced with rubber hose already
  4. Re: Fuel Lines
    1840 Post(s)
    The feed is 5 bar, the return very low pressure. Whatever, it must be done the right way. Think of it this way, last weekend seven people were burnt to death in car accidents, it depends on the way you wish to shed your mortal coil…
  5. Re: Fuel Lines
    Feb 2007
    Nottingham
    If only there were some form of internet searching facility...
    http://www.merlinmotorsport.co.uk/FU...212/index.html
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  6. Re: Fuel Lines
    1840 Post(s)
    All very well but K-Jet lines have pre formed bolt on couplings so slip on lines with band clamps are not good enough no matter how high the hose is rated.
  7. Re: Fuel Lines
    Feb 2009
    bedfordshire
    Yea given the previous post regarding the line pressure I feel that that internet site reference is no good anyway as per above post. So deffo need to get the metal pipe work then and guessing all the unions due to 19 odd years of water ingress. fingers crossed my local audio dealer still lists them then, thanks for your help crasher, very helpful.
  8. Re: Fuel Lines
    1840 Post(s)
    So it is an 1990 but what is the engine code, KV or NG, presuming it is a 5.
  9. Re: Fuel Lines
    Nov 2008
    West London
    Quote Originally Posted by comedystu View Post
    I had the same problem on my Audi 100. Phoned my local Audi dealer who quoted me between £100 - £150 for the two pipes. They are still available-at least for my car. Worth a call to Audi ?
  10. Re: Fuel Lines
    Feb 2009
    Hi Try A Seller On Ebay. Have Got A Few Parts From Audibits2 Service Is Good Always Get Parts Within 2-3 Days. Or His Email Is audibits2@aol.com Hope This Helps
  1. mk1 golf fuel lines
    By vagjunkie in forum Golf MK1 - 1974 -1984
    Last Post: 27-08-2008, 10:14 PM
  2. Question fuel lines/turbo actuator pipe
    By hongkongstuey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2008, 09:32 AM
  3. MK4 Golf TDI cold start problems: how do I remove air from fuel lines
    By peteheat in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2007, 01:37 PM
  4. TDI turbo oil lines
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-09-2007, 07:41 AM
  5. Air in fuel lines 2.5 TDi
    By brickit in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2007, 09:23 PM
