Thread: wiper linkage and rear washer jet spray
Results 1 to 10 of 10
  1. wiper linkage and rear washer jet spray
    JarvisTheCocker Guest
    Hi all
    I recently bought a 2001 Ibiza Chill and following the cold snap two things have happened.
    Firstly the wiper linkage to the passenger side wiper has dropped off it's ball joint. It appears that the rubber ring has perished. I can push it back on but it just drops off after 1 or 2 wipes. Seat have quoted £75 for a new motor and linkage. Can I get a single arm? Or can I repair the joint easily myself?
    Secondly the rear washer jet seems to have popped off. The motor works but nothing comes out. Where should I look for the break in the pipe?
    Thanks in advance for any help.
  2. Re: wiper linkage and rear washer jet spray
    Sep 2008
    Kent
    Hello mate with the wiper linkage it will need the full part and its also worth checking the rest of the linkage for wear, with regards the the back washer jet is your boot wet? Its a common fault the rubber pipe pops off the brass inlet on the washer jet inside the boot lid trim, I warn you now though its a pig to remove and you will need replacement clips from seat (approx 25p each get a few)
  3. Re: wiper linkage and rear washer jet spray
    Managed to fix the wiper linkage with a monkey wrench and a judicious crimp.
    Had the boot lid trim off, no problems with the connection there. Also no problem at the motor end. With no apparent leaks in the headliner where the pipe runs I think, why is this not working?
  4. Re: wiper linkage and rear washer jet spray
    Sep 2008
    Kent
    Have you checked the outlet pipe from the washer bottle under the bonnet?
  5. Re: wiper linkage and rear washer jet spray
    That's what I meant by the motor end. No problems visible from the bottle up to where the pipe dissapears into the chassis bulkhead.
  6. Re: wiper linkage and rear washer jet spray
    Sep 2008
    Kent
    weird they are the common areas so no water leaking into the cabin anywhere? And the screenwash level is dropping?
  7. Re: wiper linkage and rear washer jet spray
    Well the motor is certainly working and the pipe feels like liquid is moving through it. No leaks anywhere that I can find. I'm thinking if there was a blockage it would have popped off at one end too. Bit of a mystery.
  8. Re: wiper linkage and rear washer jet spray
    Sep 2008
    Kent
    Quote Originally Posted by JarvisTheCocker View Post
    This is a mystery mate! I have done a lot of work in the past on ibiza mk3's and my wife owns one but this is beating me! There has to be a leak or blockage somewhere, of course there is a oneway valve that keeps the washer pipe primed with screenwash have you held the washer pump on for more then 30 secs?
  9. Re: wiper linkage and rear washer jet spray
    No I haven't tried that. Will that make or break it?
  10. Re: wiper linkage and rear washer jet spray
    Sep 2008
    Kent
    As long as its not blocked (The motor will sound like the screenwash is empty and straining ) Then no it will be fine
  1. Windscreen washer spray adjustment
    By clarkejw in forum Golf MK5 - 2004 - 2009
    Last Post: 04-12-2008, 09:23 PM
  2. Wiper linkage..Help
    By Terri00 in forum Bora - 1998 - 2005
    Last Post: 16-10-2008, 05:14 PM
  3. Avant rear washer and wiper problem...
    By maudi25 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2008, 04:19 PM
  4. S4 Spray Type Washer System
    By Stevieb3 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2008, 06:05 PM
  5. A4 Avant Rear Windscreen wiper and washer problem
    By maudi25 in forum Archive posts
    Last Post: 18-01-2008, 10:45 PM
