Thread: Golf TD water pump.
  1. Golf TD water pump.
    Feb 2009
    I have a 96 Golf 1.9 TD ( Umwelt) which has developed a slight leak from the water pump. It looks a fairly simple job to change the pump but are there any snags that I should know about?
    Thanks,
    Ray
  2. Re: Golf TD water pump.
    Feb 2009
    Have changed half dozen of these so far, fairly straight forward except that the 'o' rings that come with the pumps have never fitted tight enough in their groove so fall out when you offer the pump up and you cannot see this so they get pinched and resuilt in water leak just when you think that you have finished.
    Cure is to buy 2 new 'o' rings from supplier of pump. They cost pence and could save you an hour or two.
  3. Re: Golf TD water pump.
    Nov 2008
    folkestone.kent
    if you coat the o ring in grease it wont fall out
  1. Water Pump
    By Stuart_B in forum Golf MK4 - 1999 - 2004
    Last Post: 28-12-2008, 08:23 AM
  2. water pump
    By stockportdubfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-11-2008, 10:03 AM
  3. Question 80 TDi Water Pump
    By beestor in forum 80 - 90
    Last Post: 13-07-2008, 12:55 PM
  4. water pump t5
    By jess james in forum The Commercial Range
    Last Post: 11-01-2008, 06:22 PM
  5. Golf 115BHP PD Cam belt/water pump
    By davey_boy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-08-2007, 01:54 PM
