Thread: Passat 1996
Results 1 to 10 of 12
  1. Passat 1996
    kevjuk04 Guest
    Help!
    Indicators stay on (steady - not flashing) when ignition turned off.
    Lights off, all switches seem OK.
    When I drive car stays same and indicators/hazards don't work; lights just stay on??
    Any ideas?
  2. Re: Passat 1996
    Hi If you can pull the connector of the hazard switch and see what happens
  3. Re: Passat 1996
    kevjuk04 Guest
    Did do, made no difference lights stay on.
    Also disconnected/reconnected battery, made no difference.
  4. Re: Passat 1996
    kevjuk04 Guest
    Also relay looks fine, not burnt out.
  5. Re: Passat 1996
    Have you replaced any bulbs recently?
  6. Re: Passat 1996
    kevjuk04 Guest
    No.
    Disconnected battery again and drivers side stay off (dont flash).
    Think it's the relay (part of the hazard switch) but odd that now only passengers side stay on.
    Getting a new hazard switch/relay Monday.
  7. Re: Passat 1996
    kevjuk04 Guest
    Fitted new relay.
    Drivers side now fine; passenger side constsntly on still even with ignition off; had to remove bulbs but dash indicator on all the time.
    Any ideas??
    PS. There is a tow bar fitted; do you think this may interfere (although it has not been touched)
  8. Re: Passat 1996
    kevjuk04 Guest
    RESOLVED - Fault traced to 'Comfort Module' which is located beneath passenger fron seat. Contains all sorts of electronic wizadry which goes wrong through damp (which of course it gets situated under the floor).
    Cleaned up corroded parts and all now works - oh except for the radio which will not come on even though fuse is OK
  9. Re: Passat 1996
    It says in my Haynes manual that one must enter the security code after disconnecting the battery. Not that it has any effect on my car as the aerial on the roof corroded away years ago. Bliss.
    Passat I.9 TD 1996 218k
  10. Re: Passat 1996
    kevjuk04 Guest
    Quote Originally Posted by the_old_diver View Post
    I would enter the code if the radio had power! Fuses are OK so wonder what else might control power to the radio?
  1. 1996 Passat TDi - difficult to get into reverse
    By melluish in forum Early Passat Forum - Pre 97
    Last Post: 20-07-2010, 05:38 PM
  2. 1996 Passat 2.0 idle problem
    By dubdaze in forum Early Passat Forum - Pre 97
    Last Post: 09-04-2009, 11:25 AM
  3. 1996 Passat Cat Converter Problems
    By lacey in forum Early Passat Forum - Pre 97
    Last Post: 20-05-2008, 10:33 PM
  4. Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    By kezia in forum Early Passat Forum - Pre 97
    Last Post: 07-01-2008, 02:44 PM
  5. Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    Last Post: 06-01-2008, 08:08 PM
