Thread: Emission MOT fail 1997 1600
Results 1 to 10 of 15
  1. Emission MOT fail 1997 1600
    Feb 2009
    garage having problems with getting emission through MOT any thoughts
  2. Re: Emission MOT fail 1997 1600
    Norfolk
    You need to post the actual emission figures.
  3. Re: Emission MOT fail 1997 1600
    Feb 2009
    Exhast Emissions carbon monoxide content after 2nd fast idle 7.3.2
    Exhast Emissions carbon monoxide content at idle 7.3.2c
  4. Re: Emission MOT fail 1997 1600
    Hi If your vehicle is a diesel,in many cases,it is could help,with the engine warm,give the vehicle a good hard run,before measurements are taken.
  5. Re: Emission MOT fail 1997 1600
    Feb 2009
    The car is a 1997 Passatt 1600 petrol . It has been losing power almost completly then picking up again the lamba sensor and another which regulates the cars themosstic contols have also beem replaced. Could it be the MAF sensor
  6. Re: Emission MOT fail 1997 1600
    What is the engine code
  7. Re: Emission MOT fail 1997 1600
    Feb 2009
    It looks like 068223
  8. Re: Emission MOT fail 1997 1600
    That is the number the code is something like AFT or AEK in front of the number
  9. Re: Emission MOT fail 1997 1600
    A faulty air mass meter will affect the emissions,as will a faulty temp sensor.Has the air filter been checked?
  10. Re: Emission MOT fail 1997 1600
    Norfolk
    The symptoms look more like a faulty lambda sensor (I see you've changed this) or faulty cat. You really need the car on the mot gas tester while you disconnect the air mass meter.
  1. vibration 1600 - 2000 rpm
    By Redzer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-04-2014, 09:35 AM
  2. Over Boosting, £1600.00 to repair!
    By whitegoatie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2009, 12:34 PM
  3. How To P. Reg 1997 Golf Mk 3 GL 1600 AFT Engine
    By leonardj in forum Golf MK3 - 1993 - 1999
    Last Post: 21-05-2008, 07:30 PM
  4. 1600 fastback
    By andy e in forum The Classic VW's
    Last Post: 04-08-2007, 10:15 AM
  5. Golf 1600 FSi
    By chinesedave in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-07-2007, 03:30 AM
