Thread: Noisy AC
Results 1 to 10 of 10
  1. Question Noisy AC
    Lanarkshire
    I've had my 2005 A4 Avant for about 4 weeks now and so far I'm really impressed with it. However there is one small niggle and that is the ammount of noise of air flowing from the vents. The only way to get rid of it seems to be either to turn the AC right off or just have the fan operating at its slowest speed.
    Have any other A4 owners had this experience?
    Quote Originally Posted by andywell View Post
    i know on my golf the AC is quite loud, but i dont think you're suposed to have it on full al the time, thats what the auto mode is for, to maintain the temp, assuming you have climate control ofcourse.
    if not, its probably best to keep it on the second to slowest setting, i never have my auto mode on my climatronic, the fan is always on its first setting, i find it keeps the temp just right, both when its cold and when its warm
    Yes- I have this on my 55 too- makes a lot of noise if you leave it on "Auto".
    I don't use "Auto" - instead, I just open the top, middle and bottom vents (by pressing the three buttons) and use the two temperature controls to set the temperature in each of the zones - it still controls the temp and fan speed automatically.
    Dec 2006
    what type of noise is it.... you dont have a stuck flap do you??
    RicKT
    If it's the same as mine it's just sounds like an enormous amount of "wind" type noise. No flaps are stuck- can easily alter the air flow manually.
    Dec 2006
    seems strange... i have never had that issue on my B6... (its the same unit in the B7)
    RiCKT
    Lanarkshire
    Quote Originally Posted by andy2 View Post
    Yip, just sounds like wind noise but as soon as I switch the AC off the noise goes
    i thought this was just the normal flow of air.... when you turn it down it dissapears, thought it was simply just the noise of the air flowing into the cabin?
    Lanarkshire
    Thanks for all your views and advice. It looks like I'll just have to play about with it and find a setting where the noise is least
    Nov 2006
    Swampyland, UK
    You may like to check to see if the "Recirc" flap is oprating correctly, or even jambed closed, as this does increase the noise.
    If you are comfortable with removing the pollen filter, you will see the recirc flap underneath that. Get a helper to toggle off and on the recirc button, and watch for full movement of the flap. Obviously with the engine idling and the blower fan running.
    For the less adventurous - turn the engine on, leave running on tick-over. Turn OFF radio/cd/SatNav/my belly (whoops, I-pod thingy! ). With the fan turned up to about half, with the face level vents open, cycle the recirc swtich on and off. It can take about 2-3 seconds for the flap to fully cycle. You should be able to "hear" a difference in the noise. The same noise should be heard when you use the screen washers, as the recirc automatically operates with the squirters!
    HTH, rgds
  1. Noisy aircon
    By swgf in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-07-2009, 10:47 PM
  2. Noisy air con
    By blakey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2007, 04:54 PM
  3. noisy tappets
    By cherryuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-05-2007, 10:30 PM
  4. Noisy Exhaust!!!
    By rottenronnie in forum Passat - Archive Topics
    Last Post: 30-03-2007, 07:45 AM
  5. Noisy aircon??
    By Mike McKinstry in forum Passat - Archive Topics
    Last Post: 14-03-2007, 09:51 AM
