Thread: a3 flashing glow plug light
  1. a3 flashing glow plug light
    Nov 2008
    hi there.....
    i have got a 2004 1.9 tdi a3 with flashing glow plug..... now i have heard about the brake light switch causing this, but my brake lights are working fine. the car also stalls when taking foot off accelerator pedal.....has this switch got a fuel cut off incorporated for mpg while braking??? had the car plugged in and only fault was a rpm flywheel sensor out of range........had it cleared and the fault stayed off when i plugged back in again.......any suggestions would be greatly appreciated. thanks guys..........
  2. Re: a3 flashing glow plug light
    Quote Originally Posted by yalittlebeauty View Post
    hi there.....
    you "named that tune in one"
    the switch will be sending false info to the ecu.
    regards,
    stewy.
    4th cog,--two to go
  3. Re: a3 flashing glow plug light
    Nov 2008
    hi stewy
    thanks for your reply
    i dont fully understand what you mean though......is my problem the brake light switch...... i took the car for a good hard drive and it seems to be going ok now no stalling or light on..... ?????
    cheers
  4. Re: a3 flashing glow plug light
    1836 Post(s)
    The switch is a dual unit, one circuit to the brake lights and the ECU and another to the ECU only as a double check for safety as the throttle is electronic so in an emergency throttle failure situation, pressing the pedal kills the throttle. What you describe is classic brake light switch failure and a fault code read should confirm this.
  5. Re: a3 flashing glow plug light
    Nov 2008
    hi crasher
    thanks for your response
    i have had the car plugged in and the error that appered was cleared and didnt reappear.......the car could idle for a couple of min or just decide to cut out after 10 seconds.... also i have only checked the brake lights when the glow plug light was out and worked fine . th light hasnt come on since this morning.......could this be an intermittent problem
    cheers
    les
  6. Re: a3 flashing glow plug light
    1836 Post(s)
    If the switch section that has a problem is the one the only sends a signal to the ECU, it will not affect the brake lights.
  1. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  2. glow plug light flashing
    By rollingroadtune in forum Alhambra
    Last Post: 12-05-2009, 03:25 PM
  3. Glow Plug Light Flashing
    By mac78 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-12-2008, 01:41 PM
  4. flashing glow plug light !help!
    By Bora Boy in forum Archive posts
    Last Post: 09-12-2007, 12:11 PM
  5. flashing glow plug light
    By imanutter in forum The Commercial Range
    Last Post: 02-12-2007, 07:12 PM
