Thread: Water leaking into footwell VW
  1. Water leaking into footwell VW
    Jan 2009
    We have just bought a VW Passat as a family car [plate 2004] it seems great but just found there is water leaking from somewhere into the driver's footwell. anyone else had this problem - I gather it may be clogged drain holes.
  2. Re: Water leaking into footwell VW
    33 Post(s)
    734 Post(s)
    Hello and welcome. You had me confused there, I was wondering how a 3C Passat (B6 if you must) was leaking as I have not had that yet, your car is a 3B Passat (B5), the up to 2005 model. Yes, it is likely to be the drains under the battery, if you do a search it is probably the most commonly asked question on the forum, that and “what oil do I use?”.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  3. Re: Water leaking into footwell VW
    Oct 2005
    Moved to the 3B section (1997 to 2005)
    See the "My Passat" link in my sig and in the first post you'll find a link to water ingress.
  4. Re: Water leaking into footwell VW
    Mar 2007
    If it is only leaking into the drivers footwell,it could be the bulkhead bonnet release cable grommet that has come adrift.
    Best,
    Frank
  5. Re: Water leaking into footwell VW
    Kinross Scotland
    It could be coming from the inner door plate seals, check the bottom of the door and the sill with a hose on the window.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  6. Re: Water leaking into footwell VW
    Feb 2009
    Quote Originally Posted by vwber View Post
    Does your heat work? Often this is the result of a failed heater core.
  1. Fluid leaking into footwell
    By Steve-T in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-02-2009, 08:14 PM
  2. Question A3 Sportback Water leaking into OS Footwell
    By Tom Leather in forum Audi A3 - Archive Topics
    Last Post: 08-07-2008, 09:27 PM
  3. Coolant leaking into footwell
    By kath in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-06-2008, 10:24 PM
  4. Please Help A6 Coolant leaking into footwell
    By kath in forum New Member Introductions
    Last Post: 09-06-2008, 06:17 PM
  5. Touran Leaking into Drivers footwell
    By AlanandEm in forum Touran - Sharan - Caravelle
    Last Post: 19-06-2007, 05:15 PM
