Thread: How do you remove the speaker grill
  1. How do you remove the speaker grill
    Liverpool
    As above on the rear passenger door and a 02 avant
  2. Re: How do you remove the speaker grill
    Sep 2007
    Windsor
    You can't. The speaker grilles are part of the door card.
  3. Re: How do you remove the speaker grill
    Liverpool
    Quote Originally Posted by xenon View Post
    You can because I have a new replacement grill but the guy said it mite have the tabs at the back melted if you know what I mean.
  4. Re: How do you remove the speaker grill
    Sep 2007
    Windsor
    The grilles are indeed 'spot welded' for want of a better term (i.e. bits of melted plastic to hold it in place). You will need to remove the door card to get to the rear of the grille so you can deal with the attachment points. I would suggest using an old soldering iron to remelt the plastic so that the old one can be removed. Don't know how successful it would be though.
  5. Re: How do you remove the speaker grill
    Liverpool
    Thanks mate, was hoping it would pul off as Iv had trouble getting on of the screws out of the door card but will try agin.
  6. Re: How do you remove the speaker grill
    Liverpool
    All done quite easy too just drilled out the old one like rivets and the used my gas soldering iron which gas a little blow torch connection to heat the connections up a little the let the burn/melt themselves down, job done and the grills only a fiver.
  1. HELP NEEDED:- 54 Reg Split Grill to Big Grill Conversion
    By craig2210 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2011, 03:03 AM
  2. Replies: 1
    Last Post: 26-12-2008, 04:29 PM
  3. Question how to remove remove aero windscreen wiper...
    By Hotrocks888 in forum Chat - Anything with wheels
    Last Post: 22-11-2008, 04:45 PM
  4. replacing a speaker grill
    By dansansome in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-07-2008, 04:23 PM
  5. GTI Grill
    By mattychellgti in forum Golf MK5 - 2004 - 2009
    Last Post: 20-03-2008, 10:19 PM
