Thread: Climate Control Too Hot
  1. Climate Control Too Hot
    Mar 2007
    Hi all, new here and with a query that I hope someone could help me with.
    I have a 1997 A6 2.5 tdi avant. The trouble is that the ac unit blows too hot. When I request HI setting, I don't get any air coming through the vents!
    I hooked up VAG COM and got the following DTC.
    01271 positioning motor for temperature flap v68
    41-00-blocked or no voltage
    Now, I am not sure how to get to this motor. Has anyone else done so? Any ideas? Thanks. Andrew.
    Dec 2006
    just to confirm its a motor on a flap which has failed....
    Sometimes you can get to them from the bottom up depending which flap it is..
    I will do some digging
    RiCKT
    Mar 2007
    Hi ,
    thanks for the reply. I have just reinstalled the blower unit back into the car. 4 hours in all (although the last 2 were with a torch). It is quite a fiddly job. I removed the temp reg flap motor and took it appart to sand some bits and bobs.
    Having reinstalled everything, it appears that the motor is working fine since the arms for moving the flap now move (they didn't before) and the Lo setting produced cold air. However I have not taken it for a test drive yet. I hope it has cured it.
    the motors for the climate system are all 7v, which makes it a pain in applying voltage on the bench for testing purposes.
    The temperature control flap motor (v68) is located in the blower assembly (LHS) on UK spec car when sat in the car. You have to take the centre console out and disconnect the ducts and cabling inside the car before disconnecting the blower unit from the coolant hoses and other wires etc. Also, the whole wiper assembly requires removal. Then you can pull the whole blower out. It is big, and it leaves the bulkhead wide open to water ingress inside the car so beware.
    Dec 2006
    Im glad to see you are back on the road with cold air for the remaining winter months!!
    RicKT
  1. B6 Climate control V B7
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 10:44 PM
  2. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  3. A4 CLIMATE CONTROL
    By Bob R in forum Chat - Completely Off Topic
    Last Post: 06-04-2007, 02:51 PM
  4. climate control, please help
    By jessicaart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-01-2007, 06:57 PM
  5. climate control
    By salty in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 28-12-2006, 10:18 AM
