Thread: Audi Coupe 1996 V6 2.6E - starting problem
  1. Wink Audi Coupe 1996 V6 2.6E - starting problem
    Jul 2008
    Hello, I have just purchased a beautiful 2.6E coupe 1st registered April 96, with a genuine 77,000 on the clock - full Audi Service History, it is immaculate and I immediately asked my favorite audi garage - All Audi to give her a full service and check it over for faults and work needed to get her up to scratch. The replaced various bushed, gaiters and the suspension mounts at the front. I also had to replace the 17" alloys and suspension springs. After driving some 3000 to 400 miles without a probelm I was caugh out by the fuel guage and nearly ran out of petrol. I nursed it to a nearby (2miles) and filled up with 95 octane unleaded, since then I have had what appear to be fuel starvation problems, some times it is a pig to start, and then after driving for 50 to 100 miles it seems to loose power, if I accellerate hard (up to 5000rpm for a minute or two) the fuel starvation problem seems to go and she runs OK for another 50 to 100 miles and it happened again. After 3 hours of this type of problem I stopped and now cannot start up the engine. There is pleany of electrical power to turn the car over, yet it will not start. If i get someone to turn the key I cannot smell any petrol coming from the exhaust, I have yet to confirm that I have a spark (Next job) but I believe I will have.
    Does anyone know what this probelm is likely to be? I think I can hear the fuel pump whine when the ignition key is turned, could I have a fuel blockage or perhaps a bubble in the fuel system, could all 6 injectors be blocked?
    Any assistance with this problem will be appreciated. Thank in anticipation.
    Ross
  2. Re: Audi Coupe 1996 V6 2.6E - starting problem
    Jan 2009
    towcester northants
    if this happened when you just filled up with fuel is the fuel contaminated ?
    remove fuel filter and drain into a clear jug leave to settle and check water will sink to bottom
    if this has happened you will need to drain tank and clean out all fuel system
  3. Re: Audi Coupe 1996 V6 2.6E - starting problem
    Jul 2008
    Quote Originally Posted by towcestervag View Post
    Thank you Towcestervag,
    I will try this, however, when I removed a plug and checked for a spark ther was none, the plus was new and covered in black soot! The garage I filled up with petrol, after the nearly running our incedent was a small independent one and I did suspect the fuel, however, I have filled up twice since then and the problem of juddering whilst driving at around 70 was still evident every 50 to 100 miles.
    I have been looking for other ideas and I think I am also going to try a new cam sensor (Hall Sender).
    I will report back when I have done this and tried the fuel check you suggest.
  4. Re: Audi Coupe 1996 V6 2.6E - starting problem
    Feb 2014
    scunthorpe(ish)
    did you get this sorted - seems to be exactly the same symptoms as whats occurring on my dads car - exactly the same car.
  1. 2.6 '95' Coupe Starting problem
    By voyagernine in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-02-2011, 12:22 AM
  2. Please Help A4 1996 1.9 tdi starting problem
    By liam walsh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-01-2009, 11:44 AM
  3. Starting problems - Audi A6 in 1996 VOLVO 850 TDI CD 1997 (Manuf 1996)
    By Grandad Dave in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 10:42 AM
  4. A4 TDI Starting Problem~1996 110 Auto
    By avantscott in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-05-2008, 10:53 AM
  5. ABK Engine 2.0 Coupe April 1996 - Starting
    By JASPER6BEARS in forum 80 - 90
    Last Post: 25-06-2007, 11:03 PM
