Thread: vent control, Speedometer, Tach.
  1. vent control, Speedometer, Tach.
    Jan 2009
    Hello all,
    I'm the new owner of a 96 Passat TDI.
    It seems like a great car but there are a few things that don't work.
    I'm pretty handy and was looking a little advice.
    The knob to change the vents to defrost, floor, ect is stuck.
    the speedometer and tachometer both just stopped working.
    Any advice would be greatly appreciated.
    thanks
    Sonomabits
  2. Re: vent control, Speedometer, Tach.
    Mar 2007
    Aberdeen
    I recently bought a 1995 Passat TDi too and it's been fitted with a new instrument panel. From searching this forum and other places it appears that it's quite a common thing to go wrong.
  3. Re: vent control, Speedometer, Tach.
    Jan 2009
    They have problem with the printed circuit behind the instruments. The wiring connector socket joints on the PCB dry out. I`ve resoldered quite a few after VW quoted telephone number prices for new ones. If you try a second hand one, the odds are that it will have the same problem as the scrappies don`t care how they disconnect them and by so doing damage the joints.
  4. Re: vent control, Speedometer, Tach.
    Jan 2009
    I just bought this car from my uncle.
    I noticed that the fuel and temp guages don't work either.
    My uncle said the issue started about the same time as he had an issue with the ignition switch not wanting to turn.
    Could this be an ignition switch issue causing the guages no to work?
    all the lights and digital displays work fine.
    Thank you all for our attention and input.
    sonomabits
  1. Please Help Speedometer Problems
    By -wasp- in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2008, 02:04 PM
  2. Speedometer Wrong?
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2008, 12:48 PM
  3. speedometer
    By majeed1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-09-2007, 02:24 AM
  4. speedometer not working
    By pritz295 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-05-2007, 08:20 AM
  5. Tach not working
    By LFK in forum Passat - Archive Topics
    Last Post: 20-12-2006, 01:57 AM
