Thread: why won't it stop??
  1. why won't it stop??
    Jan 2009
    hey guys
    my car is pinging alot.its a jetta mk2 1.8 carb.i have set the timing and the leads are all fine.what could still be causing it to ping??
    thanks
  2. Re: why won't it stop??
    Jan 2009
    towcester northants
    do you meen pinking?
    if so these cars were designed to run on leaded fuel you need to run on super unleaded or reset timing
  3. Re: why won't it stop??
    Jan 2009
    Quote Originally Posted by towcestervag View Post
    my car has always run on leaded fuel.here in south africa there are 2 types of fuel.lrp(lead replacement fuel) and unleaded.i now use lrp.u think it might have something to do with the the ignition distributor setting in terms of the number of degrees Before Top Dead Center (BTDC) or After Top Dead Center (ATDC)?
  4. Re: why won't it stop??
    Hi I think your timing is out.Although there are sometimes ,it can happen that a combination of 2 things that can cause pinking,even though the timing is correct, and that is,a high ambient temperature and poor quality fuel.However if you mean the engine will not stop when you turn off the ignition?that is a different matter
  5. Re: why won't it stop??
    Jan 2009
    Quote Originally Posted by kenney View Post
    it can't be the poor fuel because it never used to pink like this before while i was using the same fuel.i will get the timing checked and the dizzy timing and BTDC etc set.thanks
  6. Re: why won't it stop??
    Jan 2009
    Manila, PH
    What spark plugs are you using? Another thing is your fuel filter might be dirty.
  7. Re: why won't it stop??
    Jan 2009
    Quote Originally Posted by ron_dave View Post
    im using ngk spark plugs.replaced fuel filter 7000km ago.next change due in 3000km.i think the dizzy needs to be recalibrated cos thats VERY old.
  1. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
  2. I can't stop crying....
    By Col in forum Chat - Completely Off Topic
    Last Post: 31-12-2008, 01:32 AM
  3. how to stop my alarm going off - please help
    By sompop in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-12-2007, 10:27 PM
  4. Wipers won't stop!!! Help!!
    By hobbit in forum Touran - Sharan - Caravelle
    Last Post: 19-11-2007, 11:13 AM
  5. Speeding - Help me stop
    By NicholasP in forum Chat - Completely Off Topic
    Last Post: 19-05-2007, 11:05 AM
