Thread: help with fault code 00537 on mk3 golf
Results 1 to 10 of 10
  1. help with fault code 00537 on mk3 golf
    hi to all, i need some help with my golf mk3, engine code ADY 2.0l 8v, it got a missfire at 3000-4000 rpm and a slight missfire at idle, ive changed the coil pack,rotor arm,cap,leads,plugs,cat,lambda sensor,cts sensor, im getting a fault code of 00537- lambda control upper stop valve, eney help on this would be great as its doing my head in, ive also checked the timing,air leaks,fuel pressere, thanks james
  2. Re: help with fault code 00537 on mk3 golf
    Hi Think you might have a problem with one of the injectors do you know how to check them
  3. Re: help with fault code 00537 on mk3 golf
    Quote Originally Posted by kenney View Post
    i dont, do you test them useing a muiltymeter
  4. Re: help with fault code 00537 on mk3 golf
    Hi That is one way to start,but to check the injectors properly,you must remove them and check out how they function.You will see how much each injector delivers,and their patteren of the fuel delivery.It would seem you have done the most of everything else,and the fault code table points to the injectors.If you have diagnostic equipment go to measured block values and you can see the the operating condition for the lambda probe.I can send you the details if you send your e-mail address
  5. Re: help with fault code 00537 on mk3 golf
    hi,if you could send some info keney my email address is j.d.robertson@hotmail.co.uk, eney help on this would be great as im realy stuck, cheers james
  6. Re: help with fault code 00537 on mk3 golf
    Done
  7. Re: help with fault code 00537 on mk3 golf
    thanks so much
  8. Re: help with fault code 00537 on mk3 golf
    May 2009
    Germany, Frankfurt
    my name is martin and i am from germany. I was searchig thru the web to find any information about a DTC 00537 because i have the same problem with my golf gti like somebody in this forum and i saw that you gave him some introduction to solve the problem
    It will be realy kind, if you Could please tell me, what you could do to solve the problem, because i changed a lot of things the last three months, but nothing could help to solve the problems. I can´t use the car for three months ago
    We didi checked: lamda sensor + cable; oxygen-sensor + cable; timing;air leaks;fuel pressere; electric ignition; compression ( 13,5/13,5/13,5/13)
    Thank you so much, i hope you can help me.
    greeting from Frankfurt
    Bye Martin
  9. Re: help with fault code 00537 on mk3 golf
    The fault code 00537 can show two explanations,ie lambda control upper limit value and lower limit value,which reading did you get?What symptoms does the engine have?
  10. Re: help with fault code 00537 on mk3 golf
    Jul 2012
    Bogotá, Colombia
    Hi everyone, I'm new here and I need your help. I have the same problem, fault code 00537, lamba (oxygen sensor) regulation 18-00 - Upper limit. what can I do?
    thanks for everyone!!!
  1. golf tdi S 90 BHP P1556 fault code, please help
    By gti203 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:48 PM
  2. VW GOLF TDI S 90 BHP power loss P1556 fault code, please help
    By gti203 in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 19-05-2008, 10:47 PM
  3. Fault Code And A Long Story On My mk4 Golf Auto
    By golfs and stuff in forum Archive posts
    Last Post: 07-02-2008, 11:23 PM
  4. Mk3 GTI Golf ABS VAG.Com Fault Code
    By dravidham in forum Golf MK3 - 1993 - 1999
    Last Post: 01-01-2008, 11:29 PM
  5. fault code 17705 mk4 golf gti petrol aum
    By gticraig in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2007, 11:08 AM
